Visitor rubana
test bench file
I want to be able to upload the values of the various inputs into my test bench through and external text file in which the test bench should handle the capacity to understand the allocation of the various inputs against the values entered in the text file and should simulate accordingly . How do i do that?
Re: test bench file
@rubana,
Check the following Links which explains on readmemh equivalent command in VHDL with examples. Hope it helps.
--Syed
Re: test bench file
@rubana
For verilog you can use $readmemh() for such task. This will read text file that contains hex values into array.
Google to know more about this command and also refer to the below forum thread:
https://forums.xilinx.com/t5/Simulation-and-Verification/How-to-use-readmemh-in-Vivado-2013-4-simulator/td-p/402263
--Syed
Visitor rubana
Re: test bench file
what about vhdl?
Re: test bench file
@rubana,
--Syed
