Visitor smirzamo
transmit data from PCI to BRAM
Hi everybody!
I'm using Virtex 7 FPGA and PCIe bus for memory access. In what rate is the data coming from PCI bus written on BRAMs?
The speed for PCI is 8Gb/s I think but I don't think that's the rate of buffering date?
Re: transmit data from PCI to BRAM
We have a BMD test that gives us a best case throughput and were getting 7.0GB/s.
With NWL DMA, were getting 6.2GB/s with read throughput and 6.4 GB/s with write throughput.  BMD is an unrealistic design and NWL is a fully featured DMA.  If youre going to create your own DMA custom tailored for your design, you can expect to land in between 6.2 and 7.0 GB/s.
The x8 Gen 3 data with the soft cores are using Kintex-7 on the XC705.
The hardblock are obviously V7.
Thanks and Regards
Balkrishan
Visitor smirzamo
Thank u for reply.
Can u point me out to a datasheet or reference?
Visitor smirzamo
And, how much is the rate of writing on block RAMs?
