Observer syed_radiation
vc707 board files "xml" installation
I am struggling to find vc707 board installation files. Recently, I bought vc707 evaluation kit. I am looking for board files in "xml" so that while I create a project using vc707 (similar like other board, e.g. Nexys Video in picture attached) it can automatically find all peripherals constraint files.
Can you pls. send me the link to download the files?
Thanks for your kind help.
Syed
Re: vc707 board files "xml" installation
Hi @syed_radiation,
Can you please check in the install directory in path similar to below if you are able to see VC707 <install_directory>\Xilinx\Vivado\2016.2\data\boards\board_files
It seems you have installed the webpack version of the tool. That's why VC707 is not installed. I am only seeing webpack parts in the snapshot shared by you. To confirm the same please share the output of Tcl command "get_parts".
Please install Vivado Design edition/System edition to access this architecture.
Arpan
Hi @syed_radiation,
Please refer the below link
http://www.xilinx.com/support/answers/53599.html
http://www.xilinx.com/support/answer-navigation/device/boards-and-kits.html
Sarada
Scholar pratham
@syed_radiation What is the vivado version you have installed on your system? Vivado installation should come up with Xilinx Evaluation boards. Did you delete any directories?
-Pratham
@syed_radiation,
By default vc 707 board should be displayed in Vivado GUI. Did you delete any folder in Xilinx install directory?
Can you try reinstalling Vivado?
--Syed
Hi @syed_radiation,
Arpan
Hi @syed_radiation,
Did you try out the suggestions given in my earlier reply?
Arpan
Thanks for the reply. I noted that Vivado webpack doesn't support VC707 board package while Vivado design suite supports it.
Thanks for the comments.
