Visitor arjun_123
vivado 2015.2 Integrate Zynq PCIe Design and adder - IP Integrator
Hi Friends,
I am new to Xilinx vivado i want to integrate 7series pcie to adder_sub ip.
I dont know how to integrate it please provide me solution how to integrate it
I have basic example to of integrating axi example in the vivado tool.
but same thing i am trying for pcie and its not working
I am using ZC706 board.
Thanks for the support
Re: vivado 2015.2 Integrate Zynq PCIe Design and adder - IP Integrator
Hello @arjun_123,
Share the log file with error message when you are using pcie.
--Syed
Hello @arjun_123,
Check if any of the following Links are useful:
http://www.xilinx.com/training/vivado/designing-with-vivado-ip-integrator.htm
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug995-vivado-ip-subsystems-tutorial.pdf
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug994-vivado-ip-subsystems.pdf
http://www.xilinx.com/support/documentation/university/Vivado-Teaching/Digital-Design/2014x/docs-pdf/Vivado_tutorial.pdf
--Syed
