manter58
vivado 2015.2:how could I configure fpga via a programming completed flash (Zynq 7010)
I am using Vivado to program a FPGA which is xc7z010clg400-1 is a development board. I am now trying power on the board and make FPGA be configured by flash memory. If I just use program device to FPGA only, it's OK. I try to configure flash and get the response is "Flash Programming completed successfully" now, however, the board seems not work. I have no idea if something I forgot. I tried to find some help but more and more information point to do setting "Edit Device Properties" but my window has not same setting item.
Could anyone could help me ?
Best Regards
achutha
@manter58
Are you initializing the Zynq PS section?
Have you verified the functionlaity of the design just by using JTAG/XMDprogramming?
How is the QSPI image created?
Refer to the link for details on creating Zynq boot image http://www.xilinx.com/training/zynq/how-to-create-zynq-boot-image-using-xilinx-sdk.htm
-Achutha
achutha
@manter58
-Achutha
smarell
Community Manager
Community Manager
Please follow the debug guidelines provided in http://www.xilinx.com/support/answers/59174.html to narrow down or solve this issue.
manter58
