where can I find the maximum frequency of my design?
I don't know where it's mentioned,
In synthesis report, I find this:
Timing Summary:
Speed Grade: -4
Minimum period: 16.671ns (Maximum Frequency: 59.984MHz)
Minimum input arrival time before clock: 1.825ns
Maximum output required time after clock: 9.398ns
Maximum combinational path delay: No path found
but in par report, I find nothing other than that:
Generating Clock Report
|        Clock Net    |   Resource   |Locked| Fanout |Net Skew(ns)|Max Delay(ns)|
|     clk_i_BUFGP |  BUFGMUX3|     No   |   208     |       0.372     |         1.076        |
|  u2/int_clk1x_b |  BUFGMUX0|     No   |   110     |       0.442      |        1.145        |
|  i2/data_or0000 |      Local|      |             |       8      |       0.121       |        3.120        |
Constraint                                                       |     Check     |Worst Case| Best Case | Timing | Timing
        |                      |      Slack     | Achievable | Errors  | Score
OFFSET = OUT 10 ns AFTER COMP "clk"| MAXDELAY |   1.822ns  |    8.178ns   |           0 | 0
Re: where can I find the maximum frequency of my design?
Timing Summary:
Speed Grade: -4
Thanks and Regards
Balkrishan
Hi ,
The tool synthesized your design detected the clock nets and give the max frequency estimation at the end of the synthesis report.
The post par timing estimator i.e., trace will take the consideration of the ucf and runs the check against the design routed.
If you do not have any timing constraints i.e., the period constraints it will not report any thing.
Have you constrained the design in the ucf file ?
KR
ok, but can we see in par report ?
I think place and route must impact the maximum frequency
If you place the period constraints in ucf you will the clock frequency achived in post par design (ncd) file.
If there is no period constraints i think it will not estimate for any frequency check.
KR
ok, thanks you.
Are there methods to increase the maximum frequency of my design? (maximum frequency is 56 MHz and want 100 MHz)
From the timing report you can find out the path that has worst delays and try to improve it by finding alternatives, there by you can improve the max frequency
But the alternative depends on many factors of your design, few are listed below
Good Coding techniques,
Pipelining/using Synchronizers
Having Proper constarints,
Proper clocking and Reset Architecture
Uusing high frequency/low latency FPGA resources/primitives/IPs,
Global routing.
Please refer HDL coding techniques of UG687 and cross check if your design has followed Xilinx recommendations else you may consider tweaking our design
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/xst_v6s6.pdf
Below links have some info that may be helpful:
http://myfpgablog.blogspot.com/2010/11/understand-maximum-frequency-reporting.html
http://forums.xilinx.com/t5/Synthesis/Synthesis-report-Maximum-clock-frequency/td-p/247540
A bit old but good concepts on design techniques
http://www.smdp.iitkgp.ernet.in/PDF%5CXilinxPDF%5CFPGA_Design_Flow%5C16_fpgaDsgnTech_8.pdf
General google search gives below links which I think are good, you may give a try
http://www.verien.com/high_performance.htm
http://www.bu.edu/caadlab/IEEE_Computer_07.pdf
Hope this helps
Vanitha
Professor
Professor
Before you start changing things to help timing, first make sure that your UCF has the correct PERIOD constraint for the clock.  Otherwise place&route will not try to meet the required timing (because it doesn't know what it is).  Once you have the correct PERIOD constraint (100 MHz or 10 ns) you can start to see what can be achieved and what needs help to meet timing.
-- Gabor
thank you for these links.
I decided to use enable signal to decrease the frequency of flip-flops in the parts where delays are too big.
when I use enable like an input of my design and I constrains it, I have no red cross in timing report which mean frequency don't match with constraints. But when I use enable like a signal and affect it the same frequency and ratio, I get red cross. Is it normal?
