lionrouge
x4 SPI indirect programming
Hi !
I have a KC705 board and i can't make it program it's SPI Flash in x4 indirect programming mode.
What i do:
In Vivado i open implemented design and write in TCL console:
set_property BITSTREAM.CONFIG.SPI_BUSWIDTH 4 [curent_design]
The command doesn't report any errors or warnings.
Then i run iMPACT and create an MCS file.
When in IMPACT i initialize chain and select BPI/SPI it asks for Flash model and SPI mode. When i choose x4 it raises a warning saying that the MCS file was not created in x4 mode and that i shouldn't flash it that way.
How do i create an x4 SPI MCS file?
lionrouge
Looks like Vivado 2013.4 has the same bug as 2012.3 and following this advice solved my problem:
http://www.xilinx.com/support/answers/53582.html
kkn
use the following tcl command in vivado, change the bitfile name according your design file name
write_cfgmem -format mcs -interface spix4 -size 128 -loadbit "up 0x0 test.bit" -file main.mcs
--Krishna
lionrouge
I have Vivado 2013.4 so i don't have write_cfgmem command.
lionrouge
lionrouge
I faced another problem: the programming time does not look to depend on SPI clock. I set 50MHz and 25MHz and the FPGA loads the simplest firmware (one LED ligthing) for 7-9 seconds. Is it ok? Maybe i do smth. wrong?
