Anonymous
Not applicable
xapp1026 ethernet problems
Dear All
I follow the xapp1026 procedures to setup the sw
During socket mode (ml605) and zc702 system , It always happen "no such file or directory" error.
Actually I follow the new document xapp1026.pdf instructions.
Do you know why ? How to fix it ?
Maybe this question is too basic, but as I don't have more information about this issue...
Did you select to include de "lwIP" library when creating the BSP, as shown in the attached image?
Let me know if this was the problem.
Ignacio.
Tags (4)
RTOS, such as xilkernel or freeos need to run socket mode, otherwise run RAW mode apps.
J
Please check this thread. Looks like same issue solved.
http://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/Trying-to-use-XAPP1026-getting-compilation-errors/td-p/399381
KR
