xpr file opening older version of vivado
I recently installed an older version of vivado and this has changed the default setting for opening project files to the older version.  This only effects double clicking the project file itself.  Ther verision that I would like to have open by defualt is Vivado 2015.1.  Thank you for any help that you can give me.
Re: xpr file opening older version of vivado
@schumerth Please follow below steps to do so
Open Windows and search for regedit.exe (Registery Editor)
Go to HKEY_CURRENT_USER and search for Vivado.Project.1 and update the default parameter with 2015.1 (you will see 2014.4 in your case)
Please refer screenshots this would help you.
-Pratham
-Pratham
Thank you for your help.
in general, to control file association, we recommend to follow the instructions from http://www.xilinx.com/support/answers/60637.htm
We do not recommend hacking the Windows Registry. We tried it on recent versions of Vivado and it no longer works.
Best regards
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
