Digilent ATLYS board -- iMPACT does not detect it
Accepted Solution Solved
Accepted Solution
I am trying to use the ATLYS (Sp6) board.
I am succesfull in accessing it via the Digilent Adept application.
But once I try to use it form the ISE the cable not recognized.
I attach a description of the problem.
Any advice ?
thanks
Dag
Re: Digilent ATLYS board -- iMPACT does not detect it on Linux
I found the problem:
one needs to create another folder and place the files
libCseDigilent.so
libCseDigilent.xml
under it
/opt/Xilinx/13.1/ISE_DS/ISE/lib/lin/plugins/Digilent/libCseDigilent/
My mistake was that I placed the files under
I now have the Atlys board connected to the ISE (iMPACT) on Ubuntu 11.10
Dag
All Replies
According to the Digilent setup guide, the 'digilent_plugin' doesn't automatically appear in the list under iMPACT, Output, Cable Setup. Cable Plug-in. You have to type it in manually. Please give that a go!
Here is an update: I succeeded to install the board on Windows XP.
Now I am trying to make it work on Linux, Ubuntu 11.04
Linux  2.6.38-10-generic #46-Ubuntu SMP Tue Jun 28 15:05:41 UTC 2011 i686 i686 i386 GNU/Linux
on which I have intalled Xilinx Design Suite 13.1.
I did the following:
1. Extract Digilent.zip file into <Xilinx_13_1_install_Dir>\ISE_
DS\EDK\board folder.
which contains the
/opt/Xilinx/13.1/ISE_DS/EDK/board/Digilent/ipxact/Digilent_Atlys/data
2. copied The Plug-in files “libCseDigilent.so” and “libCseDigilent.xml”
into folder:
3. Installed the Adept System on Ubuntu:
 by running the install.sh
I guess it is working since I did not receive any errors while installing and when I do lsusb I see
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 003: ID 046d:c31d Logitech, Inc.
Bus 005 Device 002: ID 046d:c05a Logitech, Inc. Optical Mouse M90
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 005: ID 04e2:1410 Exar Corp.
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 006: ID 1443:0007 Digilent CoolRunner-II CPLD Starter Kit
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0bc2:2100 Seagate RSS LLC
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
4. in iMPACT I do cable setup:
I type: digilent_plugin
but I still get the mesage:
ERROR:iMPACT - Could not open plug-in of the type: digilent_plugin. Please check to make sure the correct plug-in for this type is properly installed.
The following targetNames are available:
  xilinx_svffile (libCseSvfFilePlugin)
  auto (libCseXilCommPlugin)
  xilinx_parallel (libCseXilCommPlugin)
  xilinx_platformusb (libCseXilCommPlugin)
  xilinx_file (libCseXilCommPlugin)
  xilinx_xvc (libCseXvcPlugin)
Any advise ?
thanks
Dag
libCseDigilent.so
libCseDigilent.xml
under it
Dag
Where did you get the plugins directory under Xilinx/ISE/bin/lin ? my installation doesn't sho anything like that.
I have the digilent directory but not the plugins
C
Just create it yourself
How do I solve the problem? My atlys board isnt being recognized by the adept. Please tell me steps to be taken after installing ise and adept. I am working on windows 8.1/10 . xilinx 13.2 installed
@saahil.kitture11 ISE 13.2 is not compatible with Windows 8.1/10. Are you sure Adept is compatible?
Just FYI, try opening a new thread than posting on a solved thread to get more visibility and responses.
