prabhjot.kaur
10 G SFP evaluation board with 100T xilinx FPGA
Hello sir/ Mam
We are looking for 10 G SFP board of Xilinx with 70T to 100T logic cells or a higher Logic cell FPGA which is Backward compatible with 70 to 100T logic cell FPGA.
anatoli
Hello @prabhjot.kaur ,
The best place to start for you, in relation to be able to find the correct board for your design, is to reach out to your local Xilinx Sales Representative/Xilinx FAE/Authorized Distributor, as they sale Xilinx boards, so they would know and would be able to recommend you in relation of the required and correct board for your application.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
Bowers
What board did you choose? Actually, you may go either with Virtex7 or Kintex7. But with Kintex7, if it's a FBG900 or FBG676 package, the board can support 6.6Gb only. I chose a XILINX Kintex 7 XC K420T SFP+ 10G FPGA board.
Steve
Aucra Tech
writemyessaytoday.net
