tehpyrate
50Mhz Clock Dividing to 30Mhz..
I'm not really sure how to go about doing this...
My application:
I have 3 ADCs sampling at 10 Mhz (100 ns) Simultaneously
I have a multiplexer that grabs the data off each ADC, Feeds it into a buffer which gets shoved into RAM via Burst Write mode.
My nexys 2 board has a 50 Mhz (20 ns, samples 3 ADCs 5 times..) crystal oscillator. If I use that, I end up grabbing the Data from ADC 1 and ADC 2 twice. I do not want to do that.
So I did the math out, If I want to grab the data off the 3ADCs within the sample time I would need a clock speed of 30Mhz (100 ns/ 33.333 ns ~ 3 )
so Basically I need to go from a 50Mhz to a 30 Mhz clock.. so basically the clock needs to say High for 16.66ns and low for 16.66 ns. I can't seem to do it using a conventional method of using a counter.. any thoughts?
eteam00
Professor
Professor
You don't need a 30MHz clock to read or sample periodically.  As long as the ADC interfaces will run at 50MHz, why not run the interfaces at 50MHz?
I don't think a clock frequency change is likely to affect this problem.  It will only make the problem "run" faster or slower.
-- Bob Elkind
SIGNATURE:
Summary:
tehpyrate
I'm using external ADCs that run at max of 10Mhz.
eteam00
Professor
Professor
How can we help you?
-- Bob Elkind
SIGNATURE:
Summary:
bassman59
Historian
Historian
My application:
Sounds like a problem for a simple state machine.
Or you could replace the 50 MHz oscillator with a 30 MHz oscillator and get on with your life.
sonicwave
If by "conventional" method you mean using a counter to generate a new clock, you should probably have a look at using clock enables (or a DCM) instead. Gated / derived clocks can introduce subtle timing problems, especially when used with multiple clock domains. Also, if you make several of these, you'll quickly use up all your clock lines in the FPGA. Clock enables have neither of these problems, and also allows you much better control of the timing granularity...
