A Question About the Connection between k-7 FPGA Evaluation Kit and TI TMDSEVM 6678L
Hellow,
    We are designing a GNSS Receiver and we use FPFA(k-7 evaluation kit) as correlators and DSP(TI TMS320C6678 EVM) as controler.The DSP could configue the registers in FPGA.Now we have a question here, what interface shoud we use to connect the two evaluation board.Are there some Well-understood methods? The picture below displays the featrues of the 6678 EVM board.
Re: A Question About the Connection between k-7 FPGA Evaluation Kit and TI TMDSEVM 6678L
The KC705 example reference designs can be found in the below link. Please refer nearest example reference.
http://www.xilinx.com/products/boards-and-kits/ek-k7-kc705-g.html#documentation
