q2418130103p
AC701 to AC701 GTP Throughput
I would like to test some board-to-board data transfer rates and latencies using some AC701 dev boards.
What could I realistically expect to get for throughput between two AC701 dev boards via the GTP transciever (SMA)?
athandr
If you are looking for the Data Rates then the Artix devices have GTP's in them which give a data rate from 500Mbps to 6.6Gbps realistically for transfer between the two AC701 boards.
Anirudh
PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.
q2418130103p
I guess my question is a bit less practical than I thought, what I am looking to take a guess at is what throughput could be obtained given the connection is via four seperate coaxs.
