pjurgielewicz
ADV7511 & I2C on KCU116
Hello everyone,
I am trying to create a design making use of HDMI output on kcu116 evaluation board. The problem is that this board has different type of connection to the I2C bus. Previously I was using vc707 where ADV7511 was connected via 1-to-8 switch (0x74) channel 5, 0x39 and I successfully managed to run it.
Here however ADV7511 is not existing directly on the I2C bus architecture scheme (ug1239 p.55) but there are entries in the Master Contraints File Listing:
#HDMI IIC
set_property PACKAGE_PIN AE15 [get_ports "IIC_SDA_HDMI"] ;
set_property IOSTANDARD LVCMOS33 [get_ports "IIC_SDA_HDMI"] ;
set_property PACKAGE_PIN AD15 [get_ports "IIC_SCL_HDMI"] ;
set_property IOSTANDARD LVCMOS33 [get_ports "IIC_SCL_HDMI"] ;
So, in my design I added constraints:
set_property PACKAGE_PIN AE15 [get_ports "iic_rtl_sda_io"]
set_property IOSTANDARD LVCMOS33 [get_ports "iic_rtl_sda_io"]
set_property PACKAGE_PIN AD15 [get_ports "iic_rtl_scl_io"]
set_property IOSTANDARD LVCMOS33 [get_ports "iic_rtl_scl_io"]
where iic_rtl is the output from AXI_IIC (IIC) and AXI_IIC is conntected to Microblaze via interconnect.
Now I am trying to setup ADV7511 with this directly connected I2C bus and here my question arises:
How should I modify my old code (working with vc707) to make it communicate properly on kcu116?
My code is provided in attachments.
Many thanks for your advice and help.
pjurgielewicz
Hi @florentw,
I made the simplified version of my design: just MIG + MB + AXI IIC and copy-pasted the code I provided in the very first post (with the same constraints). Then I removed IIC switch choice in SDK code and... it seems to be working. I am able to write and read proper values. However exactly the same code is not working in the previous design - this is a kind of another story (I can recreate it based on this working piece).
Just one thing to clarify here (may be benefitial for the others):
By default AXI IIC uses 7-bit address mode so the address 0x39 (from UG) is in fact 0x72 from ADV7511 product page (0x39 << 1 = 0x72).
florentw
Hi @pjurgielewicz,
Note I haven't read your code but base on the difference between the boards:
You might need to remove the code to control the switch and then use the direct I2C address for the ADV7511 which should be 0x72
Florent
pjurgielewicz
Hi @florentw
thanks for your reply.
As you suggested I removed the code responsible for switch setup and hard-coded 0x72 as the address of ADV7511:
EepromIicAddr = 0x72;
but it is not working either.  EepromWriteByte() returns the number of bytes written to the device and in case of ADV7511 it should always be 1 byte. Whereas in the case the address is wrong it returns 255 - and this is what I receive. After EepromWriteByte() I am waiting 50000 cycles in a loop and then I try to read written value back. However I2C is not able to find anything at 0x72 and gets stuck in the while loop:
do {
		StatusReg = XIic_ReadReg(IIC_BASE_ADDRESS, XIIC_SR_REG_OFFSET);
		if (!(StatusReg & XIIC_SR_BUS_BUSY_MASK)) {
			SentByteCount = XIic_DynSend(IIC_BASE_ADDRESS,
                                    EepromIicAddr,
                                    (u8 *) &Address,
                                    sizeof(Address),
                                    XIIC_REPEATED_START);
	} while (SentByteCount != sizeof(Address));
I am wondering how did you find 0x72 as the address of ADV7511 in this setup?
florentw
Hi @pjurgielewicz,
I have found the address 0x72 in the ADV7511 SW programming guide:
However, I might be wrong because from some UG for Xilinx board, the address after the swith is 0x39 (example with KCU105):
Florent
pjurgielewicz
Hi @florentw,
