AMS101 Card Evaluatioin
Hi @pkiang ,
Please find the requested files: rdf0280-ams101-kc705-trd-2013-3.zip  and regarding xadc_eval_design_XXABC/ready_to_test  , you can find that BIT File from rdf0280-ams101-kc705-trd-2013-3.zip . BIT File is present in xadc_eval_design_XXABC/ready_to_test as below image:
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Hi @pkiang ,
Deepak D N
It works, thank you very much!
