sai_deepthi
AXI 4 UART Lite
Hello there,
Can we make use of AXI-4 UART lite IP Core without instantiating Microblaze IP Core and launching XSDK on KC705 evaluation board?
Thanks in advance.
Deepthi
u4223374
Advisor
Advisor
Yes, absolutely. You just need an AXI Master to drive it.
dgisselq
There are plenty of open UART IP cores you can use that might be easier to drive, and don't require either a microblaze, AXI master, or AXI interconnect to use.  You could also create your own--they aren't that hard.  Here's a tutorial discussing how to do so.
Dan
sai_deepthi
Thanks for replying.
You mean an AXI Traffic generator IP Core to be used as master ?
dgisselq
@sai_deepthi,
The AXI traffic generator IP core looks like its purpose is to test and verify whether or not generated AXI signals match the standard, rather than a general purpose AXI master.
Your goal was to control an AXI UART lite, but without the heavy weight of a processor, interconnect, etc.  This is still quite doable--but requires writing your own AXI (lite?) master to control it.
I brought up the alternative of not using AXI at all, but it would require using a different UART core.
Dan
sai_deepthi
But I need to do it using AXI bus interface only as it is proven IP in vivado.
Anyways, thank you for sharing information about AXI traffic generator.
Deepthi.
