Visitor xiaomengmiao
About Zynq UltraScale MPSoC Base TRD 2018.2,moudle 5
I followed the steps by https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841924/Zynq+UltraScale+MPSoC+Base+TRD+2018.2+-+Design+Module+5
But it shows,
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841924/Zynq+UltraScale+MPSoC+Base+TRD+2018.2+-+Design+Modroot@xilinx:~# run_video.sh
** Zynq UltraScale+ MPSoC Base TRD Qt Application **
Starting application...
expr: warning: '^/dev/tty[0-9]\+$': using '^' as the first character
of a basic regular expression is not portable; it is ignored
hostname: xilinx: Host name lookup failure
xauth:  file /home/root/.serverauth.2651 does not exist
X.Org X Server 1.19.3
Release Date: 2017-03-15
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.4.0-31-generic x86_64
Current Operating System: Linux xilinx 4.14.0-xilinx-v2018.2 #1 SMP Fri Jun 21 17:29:23 CST 2019 aarch64
Kernel command line: earlycon clk_ignore_unused root=/dev/ram rw earlyprintk uio_pdrv_genirq.of_id=xlnx,generic-uio cma=1024M cpuidle.off=1 cpufreq.off=1
Build Date: 21 June 2019  06:33:29PM
Current version of pixman: 0.34.0
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.3.log", Time: Thu Jul 18 14:04:29 2019
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
Unable to query physical screen size, defaulting to 100 dpi.
To override, set QT_QPA_EGLFS_PHYSICAL_WIDTH and QT_QPA_EGLFS_PHYSICAL_HEIGHT (in millimeters).
I did this:
set QT_QPA_EGLFS_PHYSICAL_WIDTH=1920
set QT_QPA_EGLFS_PHYSICAL_HEIGHT=1080
But it didn't work, is there any solutions? Thanks
Tags (3)
Mentor watari
Mentor
Re: About Zynq UltraScale MPSoC Base TRD 2018.2,moudle 5
Hi @xiaomengmiao
Would you post /var/log/Xorg.3.log file ?
Best regards,
Thanks, this is the log file.
Xilinx Zynq MP First Stage Boot Loader
Release 2018.2   Jun 22 2019  -  14:01:10
NOTICE:  ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v1.4(release):xilinx-v2018.1-4-g93a69a5a
NOTICE:  BL31: Built : 13:53:56, Jun 21 2019
PMUFW:  v1.0
U-Boot 2018.01 (Jun 21 2019 - 21:50:24 +0800) Xilinx ZynqMP ZCU102 rev1.0
I2C:   ready
DRAM:  4 GiB
EL Level:       EL2
Chip ID:        zu9eg
MMC:   sdhci@ff170000: 0 (SD)
SF: Detected n25q512a with page size 512 Bytes, erase size 128 KiB, total 128 Mi                                                           B
In:    serial@ff000000
Out:   serial@ff000000
Err:   serial@ff000000
Model: ZynqMP ZCU102 Rev1.0
Board: Xilinx ZynqMP
Bootmode: LVL_SHFT_SD_MODE1
Net:   ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
Warning: ethernet@ff0e0000 using MAC address from ROM
eth0: ethernet@ff0e0000
Device: sdhci@ff170000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
162367340 bytes read in 10419 ms (14.9 MiB/s)
   Using 'conf@system-top.dtb' configuration
   Trying 'kernel@1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x10000108
     Data Size:    7045989 Bytes = 6.7 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   75dd9eb52ac0806ebf948053bc3565620ae55c46
   Verifying Hash       FIT Image at 10000000 ...
   Trying 'ramdisk@1' ramdisk subimage
     Description:  petalinux-user-image
     Type:         RAMDisk Image
     Data Start:   0x106c2784
     Data Size:    155277909 Bytes = 148.1 MiB
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   343a3d745c3e560b8df2c752fd6652f2561915e9
   Trying 'fdt@system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Compression:  uncompressed
     Data Start:   0x106b8574
     Data Size:    41291 Bytes = 40.3 KiB
     Hash algo:    sha1
     Hash value:   60cc1e1160674ba11ea0b7ea3298d0eb3d40847c
   Booting using the fdt blob at 0x106b8574
   Uncompressing Kernel Image ... OK
   Loading Ramdisk to 74977000, end 7dd8ca55 ... OK
   Loading Device Tree to 0000000074969000, end 000000007497614a ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.0-xilinx-v2018.2 (oe-user@oe-host) (gcc versio                                                           n 7.2.0 (GCC)) #1 SMP Fri Jun 21 17:29:23 CST 2019
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] Machine model: ZynqMP ZCU102 Rev1.0
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 1024 MiB at 0x0000000034800000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] random: fast init done
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff65000 s46488 r8192 d313                                                           36 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1033987
[    0.000000] Kernel command line: earlycon clk_ignore_unused root=/dev/ram rw                                                            earlyprintk uio_pdrv_genirq.of_id=xlnx,generic-uio cma=1024M cpuidle.off=1 cpufr                                                           eq.off=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes                                                           )
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0x30800000-0x34800000] (64MB) mapped at [fff                                                           fffc030800000-ffffffc0347fffff]
[    0.000000] Memory: 2846076K/4193280K available (10044K kernel code, 652K rwd                                                           ata, 3192K rodata, 512K init, 2353K bss, 298628K reserved, 1048576K cma-reserved                                                           )
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 M                                                           B)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 G                                                           B)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008a50000   ( 10048 K                                                           B)
[    0.000000]     .rodata : 0xffffff8008a50000 - 0xffffff8008d80000   (  3264 K                                                           B)
[    0.000000]       .init : 0xffffff8008d80000 - 0xffffff8008e00000   (   512 K                                                           B)
[    0.000000]       .data : 0xffffff8008e00000 - 0xffffff8008ea3200   (   653 K                                                           B)
[    0.000000]        .bss : 0xffffff8008ea3200 - 0xffffff80090ef9b0   (  2354 K                                                           B)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 K                                                           B)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 M                                                           B)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 G                                                           B maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf1dc00000   (   476 M                                                           B actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc880000000   ( 34816 M                                                           B)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU event tracing is enabled.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:                                                            0x170f8dc196, max_idle_ns: 440795203664 ns
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 43980                                                           46511099ns
[    0.008302] Console: colour dummy device 80x25
[    0.012559] console [tty0] enabled
[    0.015926] bootconsole [cdns0] disabled
[    0.019837] Calibrating delay loop (skipped), value calculated using timer fr                                                           equency.. 199.98 BogoMIPS (lpj=399960)
[    0.019850] pid_max: default: 32768 minimum: 301
[    0.019952] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.019969] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.020525] ASID allocator initialised with 65536 entries
[    0.020574] Hierarchical SRCU implementation.
[    0.020900] EFI services will not be available.
[    0.020925] zynqmp_plat_init Platform Management API v1.0
[    0.020933] zynqmp_plat_init Trustzone version v1.0
[    0.021028] smp: Bringing up secondary CPUs ...
[    0.021280] Detected VIPT I-cache on CPU1
[    0.021307] CPU1: Booted secondary processor [410fd034]
[    0.021580] Detected VIPT I-cache on CPU2
[    0.021597] CPU2: Booted secondary processor [410fd034]
[    0.021859] Detected VIPT I-cache on CPU3
[    0.021876] CPU3: Booted secondary processor [410fd034]
[    0.021917] smp: Brought up 1 node, 4 CPUs
[    0.021949] SMP: Total of 4 processors activated.
[    0.021957] CPU features: detected feature: 32-bit EL0 Support
[    0.021968] CPU: All CPU(s) started at EL2
[    0.021984] alternatives: patching kernel code
[    0.022696] devtmpfs: initialized
[    0.027378] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma                                                           x_idle_ns: 7645041785100000 ns
[    0.027401] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.048411] xor: measuring software checksum speed
[    0.087967]    8regs     :  2302.000 MB/sec
[    0.127997]    8regs_prefetch:  2052.000 MB/sec
[    0.168028]    32regs    :  2830.000 MB/sec
[    0.208058]    32regs_prefetch:  2381.000 MB/sec
[    0.208066] xor: using function: 32regs (2830.000 MB/sec)
[    0.208140] pinctrl core: initialized pinctrl subsystem
[    0.208627] NET: Registered protocol family 16
[    0.209791] vdso: 2 pages (1 code @ ffffff8008a56000, 1 data @ ffffff8008e040                                                           00)
[    0.209809] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.210381] DMA: preallocated 256 KiB pool for atomic allocations
[    0.239845] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.240401] ARM CCI_400_r1 PMU driver probed
[    0.244951] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.252712] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.320301] raid6: int64x1  gen()   403 MB/s
[    0.388247] raid6: int64x1  xor()   446 MB/s
[    0.456312] raid6: int64x2  gen()   689 MB/s
[    0.524333] raid6: int64x2  xor()   602 MB/s
[    0.592406] raid6: int64x4  gen()  1042 MB/s
[    0.660428] raid6: int64x4  xor()   741 MB/s
[    0.728472] raid6: int64x8  gen()   979 MB/s
[    0.796535] raid6: int64x8  xor()   745 MB/s
[    0.864591] raid6: neonx1   gen()   726 MB/s
[    0.932629] raid6: neonx1   xor()   852 MB/s
[    1.000655] raid6: neonx2   gen()  1169 MB/s
[    1.068710] raid6: neonx2   xor()  1206 MB/s
[    1.136762] raid6: neonx4   gen()  1504 MB/s
[    1.204802] raid6: neonx4   xor()  1440 MB/s
[    1.272842] raid6: neonx8   gen()  1651 MB/s
[    1.340907] raid6: neonx8   xor()  1532 MB/s
[    1.340914] raid6: using algorithm neonx8 gen() 1651 MB/s
[    1.340922] raid6: .... xor() 1532 MB/s, rmw enabled
[    1.340929] raid6: using neon recovery algorithm
[    1.342268] SCSI subsystem initialized
[    1.342429] usbcore: registered new interface driver usbfs
[    1.342466] usbcore: registered new interface driver hub
[    1.342505] usbcore: registered new device driver usb
[    1.342573] media: Linux media interface: v0.10
[    1.342598] Linux video capture interface: v2.00
[    1.342637] pps_core: LinuxPPS API ver. 1 registered
[    1.342645] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome                                                           tti <giometti@linux.it>
[    1.342665] PTP clock support registered
[    1.342690] EDAC MC: Ver: 3.0.0
[    1.342982] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
[    1.343119] FPGA manager framework
[    1.343220] fpga-region fpga-full: FPGA Region probed
[    1.343306] Advanced Linux Sound Architecture Driver Initialized.
[    1.343555] Bluetooth: Core ver 2.22
[    1.343585] NET: Registered protocol family 31
[    1.343593] Bluetooth: HCI device and connection manager initialized
[    1.343604] Bluetooth: HCI socket layer initialized
[    1.343614] Bluetooth: L2CAP socket layer initialized
[    1.343631] Bluetooth: SCO socket layer initialized
[    1.344211] clocksource: Switched to clocksource arch_sys_counter
[    1.344283] VFS: Disk quotas dquot_6.6.0
[    1.344328] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.348199] NET: Registered protocol family 2
[    1.348509] TCP established hash table entries: 32768 (order: 6, 262144 bytes                                                           )
[    1.348719] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.349102] TCP: Hash tables configured (established 32768 bind 32768)
[    1.349170] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.349248] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.349394] NET: Registered protocol family 1
[    1.349636] RPC: Registered named UNIX socket transport module.
[    1.349646] RPC: Registered udp transport module.
[    1.349653] RPC: Registered tcp transport module.
[    1.349660] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.349753] Trying to unpack rootfs image as initramfs...
[    7.466716] Freeing initrd memory: 151636K
[    7.467188] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    7.467342] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters av                                                           ailable
[    7.467997] audit: initializing netlink subsys (disabled)
[    7.468080] audit: type=2000 audit(7.452:1): state=initialized audit_enabled=                                                           0 res=1
[    7.468430] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[    7.469111] NFS: Registering the id_resolver key type
[    7.469131] Key type id_resolver registered
[    7.469138] Key type id_legacy registered
[    7.469151] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    7.469172] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    7.495716] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2                                                           46)
[    7.495736] io scheduler noop registered
[    7.495744] io scheduler deadline registered
[    7.495765] io scheduler cfq registered (default)
[    7.495774] io scheduler mq-deadline registered
[    7.495781] io scheduler kyber registered
[    7.496950] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    7.497363] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    7.497526] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    7.497689] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    7.497849] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    7.498009] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    7.498168] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    7.498324] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    7.498489] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    7.498709] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    7.498859] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    7.499008] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    7.499159] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    7.499310] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    7.499460] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    7.499617] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    7.499769] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    7.524170] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    7.526919] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    7.530926] brd: module loaded
[    7.534216] loop: module loaded
[    7.535021] ahci-ceva fd0c0000.ahci: couldn't get PHY in node ahci: -517
[    7.535165] mtdoops: mtd device (mtddev=name/number) must be supplied
[    7.536194] m25p80 spi0.0: n25q512a (131072 Kbytes)
[    7.536243] 4 ofpart partitions found on MTD device spi0.0
[    7.536252] Creating 4 MTD partitions on "spi0.0":
[    7.536264] 0x000000000000-0x000001e00000 : "boot"
[    7.536719] 0x000001e00000-0x000001e40000 : "bootenv"
[    7.537095] 0x000001e40000-0x000004240000 : "kernel"
[    7.537467] 0x000004240000-0x000008000000 : "spare"
[    7.538657] libphy: Fixed MDIO Bus: probed
[    7.539628] tun: Universal TUN/TAP device driver, 1.6
[    7.539780] CAN device driver interface
[    7.541770] macb ff0e0000.ethernet: Not enabling partial store and forward
[    7.542131] libphy: MACB_mii_bus: probed
[    7.545257] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e                                                           0000 irq 31 (00:0a:35:04:e8:d9)
[    7.545275] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI                                                            DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL)
[    7.545789] usbcore: registered new interface driver asix
[    7.545841] usbcore: registered new interface driver ax88179_178a
[    7.545872] usbcore: registered new interface driver cdc_ether
[    7.545902] usbcore: registered new interface driver net1080
[    7.545931] usbcore: registered new interface driver cdc_subset
[    7.545962] usbcore: registered new interface driver zaurus
[    7.546002] usbcore: registered new interface driver cdc_ncm
[    7.546289] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    7.547331] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    7.547341] ehci-pci: EHCI PCI platform driver
[    7.547572] usbcore: registered new interface driver uas
[    7.547610] usbcore: registered new interface driver usb-storage
[    7.548067] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc                                                           0
[    7.548115] i2c /dev entries driver
[    7.549146] IR NEC protocol handler initialized
[    7.549156] IR RC5(x/sz) protocol handler initialized
[    7.549163] IR RC6 protocol handler initialized
[    7.549170] IR JVC protocol handler initialized
[    7.549177] IR Sony protocol handler initialized
[    7.549184] IR SANYO protocol handler initialized
[    7.549191] IR Sharp protocol handler initialized
[    7.549198] IR MCE Keyboard/mouse protocol handler initialized
[    7.549205] IR XMP protocol handler initialized
[    7.549336] vivid-000: using single planar format API
[    7.550875] vivid-000: V4L2 capture device registered as video0
[    7.550943] vivid-000: V4L2 output device registered as video1
[    7.551015] vivid-000: V4L2 capture device registered as vbi0, supports raw a                                                           nd sliced VBI
[    7.551088] vivid-000: V4L2 output device registered as vbi1, supports raw an                                                           d sliced VBI
[    7.551158] vivid-000: V4L2 capture device registered as swradio0
[    7.551224] vivid-000: V4L2 receiver device registered as radio0
[    7.551290] vivid-000: V4L2 transmitter device registered as radio1
[    7.552266] usbcore: registered new interface driver uvcvideo
[    7.552275] USB Video Class driver (1.1.1)
[    7.552778] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff800917                                                           d000 with timeout 10s
[    7.552952] Bluetooth: HCI UART driver ver 2.3
[    7.552962] Bluetooth: HCI UART protocol H4 registered
[    7.552970] Bluetooth: HCI UART protocol BCSP registered
[    7.552996] Bluetooth: HCI UART protocol LL registered
[    7.553005] Bluetooth: HCI UART protocol ATH3K registered
[    7.553013] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    7.553053] Bluetooth: HCI UART protocol Intel registered
[    7.553062] Bluetooth: HCI UART protocol QCA registered
[    7.553099] usbcore: registered new interface driver bcm203x
[    7.553131] usbcore: registered new interface driver bpa10x
[    7.553166] usbcore: registered new interface driver bfusb
[    7.553200] usbcore: registered new interface driver btusb
[    7.553209] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    7.553258] usbcore: registered new interface driver ath3k
[    7.553384] EDAC MC: ECC not enabled
[    7.553550] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac control                                                           ler zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    7.553843] cpufreq-dt cpufreq-dt: failed register driver: -19
[    7.553868] CPUidle arm: Failed to register cpuidle driver
[    7.553999] sdhci: Secure Digital Host Controller Interface driver
[    7.554008] sdhci: Copyright(c) Pierre Ossman
[    7.554015] sdhci-pltfm: SDHCI platform and OF driver helper
[    7.600418] mmc0: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using A                                                           DMA 64-bit
[    7.606465] ledtrig-cpu: registered to indicate activity on CPUs
[    7.606609] usbcore: registered new interface driver usbhid
[    7.606617] usbhid: USB HID core driver
[    7.608493] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    7.610229] pktgen: Packet Generator for packet performance testing. Version:                                                            2.75
[    7.612449] Netfilter messages via NETLINK v0.30.
[    7.612565] ip_tables: (C) 2000-2006 Netfilter Core Team
[    7.612693] Initializing XFRM netlink socket
[    7.612752] NET: Registered protocol family 10
[    7.613160] Segment Routing with IPv6
[    7.613204] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    7.613320] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    7.613628] NET: Registered protocol family 17
[    7.613644] NET: Registered protocol family 15
[    7.613662] bridge: filtering via arp/ip/ip6tables is no longer available by                                                            default. Update your scripts to load br_netfilter if you need this.
[    7.613676] Ebtables v2.0 registered
[    7.613763] can: controller area network core (rev 20170425 abi 9)
[    7.613796] NET: Registered protocol family 29
[    7.613811] can: raw protocol (rev 20170425)
[    7.613819] can: broadcast manager protocol (rev 20170425 t)
[    7.613830] can: netlink gateway (rev 20170425) max_hops=1
[    7.614057] Bluetooth: RFCOMM TTY layer initialized
[    7.614072] Bluetooth: RFCOMM socket layer initialized
[    7.614087] Bluetooth: RFCOMM ver 1.11
[    7.614097] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    7.614105] Bluetooth: BNEP filters: protocol multicast
[    7.614115] Bluetooth: BNEP socket layer initialized
[    7.614123] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    7.614133] Bluetooth: HIDP socket layer initialized
[    7.614238] 9pnet: Installing 9P2000 support
[    7.614261] Key type dns_resolver registered
[    7.614701] registered taskstats version 1
[    7.615043] Btrfs loaded, crc32c=crc32c-generic
[    7.620275] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 42, base_baud =                                                            6249375) is a xuartps
[    7.779872] mmc0: new high speed SDHC card at address aaaa
[    7.784163] mmcblk0: mmc0:aaaa SB16G 14.8 GiB
[    7.791697]  mmcblk0: p1
[    9.261883] console [ttyPS0] enabled
[    9.267186] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_lo                                                           cked:yes
[    9.275402] PLL: shutdown
[    9.278086] PLL: shutdown
[    9.281003] PLL: enable
[    9.283490] PLL: shutdown
[    9.286844] PLL: enable
[    9.289315] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0:                                                            Xilinx DisplayPort Sound Codec probed
[    9.299906] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PC                                                           M probed
[    9.307852] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PC                                                           M probed
[    9.316094] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xi                                                           linx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    9.328453] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xi                                                           linx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    9.341037] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xi                                                           linx DisplayPort Sound Card probed
[    9.351136] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[    9.358057] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    9.364589] [drm] No driver support for vblank timestamp query.
[    9.370548] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8                                                           008b07128)
[    9.401893] zynqmp-display fd4a0000.zynqmp-display: fb0:  frame buffer device
[    9.409129] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display                                                            on minor 0
[    9.417158] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsys                                                           tem driver probed
[    9.426143] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_lo                                                           cked:yes
[    9.433947] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0                                                           x3 impl platform mode
[    9.442837] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fb                                                           s pio slum part ccc sds apst
[    9.453133] scsi host0: ahci-ceva
[    9.456544] scsi host1: ahci-ceva
[    9.459871] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x1                                                           00 irq 40
[    9.467715] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x1                                                           80 irq 40
[    9.477278] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_lo                                                           cked:yes
[    9.487251] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    9.492672] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus nu                                                           mber 1
[    9.500540] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100                                                            quirks 0x22010010
[    9.509192] xhci-hcd xhci-hcd.0.auto: irq 47, io mem 0xfe200000
[    9.515176] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    9.521891] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=                                                           1
[    9.529093] usb usb1: Product: xHCI Host Controller
[    9.533952] usb usb1: Manufacturer: Linux 4.14.0-xilinx-v2018.2 xhci-hcd
[    9.540637] usb usb1: SerialNumber: xhci-hcd.0.auto
[    9.545770] hub 1-0:1.0: USB hub found
[    9.549461] hub 1-0:1.0: 1 port detected
[    9.553518] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    9.558931] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus nu                                                           mber 2
[    9.566610] usb usb2: We don't know the algorithms for LPM for this host, dis                                                           abling LPM.
[    9.574708] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    9.581414] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=                                                           1
[    9.588618] usb usb2: Product: xHCI Host Controller
[    9.593476] usb usb2: Manufacturer: Linux 4.14.0-xilinx-v2018.2 xhci-hcd
[    9.600161] usb usb2: SerialNumber: xhci-hcd.0.auto
[    9.605246] hub 2-0:1.0: USB hub found
[    9.608930] hub 2-0:1.0: 1 port detected
[    9.613900] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulato                                                           r
[    9.623861] pca953x 0-0020: interrupt support not compiled in
[    9.629624] pca953x 0-0021: 0-0021 supply vcc not found, using dummy regulato                                                           r
[    9.639613] pca953x 0-0021: interrupt support not compiled in
[    9.646062] ina2xx 3-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.652754] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.659454] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.666144] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.672838] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.679537] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.686231] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.692915] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.699607] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.706298] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.712605] i2c i2c-0: Added multiplexed i2c bus 3
[    9.717935] ina2xx 4-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[    9.724641] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.731334] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.738035] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.744727] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.751423] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.758116] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.764805] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[    9.771110] i2c i2c-0: Added multiplexed i2c bus 4
[    9.790385] ata2: SATA link down (SStatus 0 SControl 330)
[    9.795738] ata1: SATA link down (SStatus 0 SControl 330)
[    9.816258] i2c i2c-0: Added multiplexed i2c bus 5
[    9.821088] i2c i2c-0: Added multiplexed i2c bus 6
[    9.825800] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca95                                                           44
[    9.833113] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 33
[    9.840636] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[    9.847290] i2c i2c-1: Added multiplexed i2c bus 7
[    9.852221] i2c i2c-1: Added multiplexed i2c bus 8
[    9.858925] si570 9-005d: registered, current frequency 300000000 Hz
[    9.865228] i2c i2c-1: Added multiplexed i2c bus 9
[    9.883874] si570 10-005d: registered, current frequency 148500000 Hz
[    9.890263] i2c i2c-1: Added multiplexed i2c bus 10
[    9.895282] i2c i2c-1: Added multiplexed i2c bus 11
[    9.900190] i2c i2c-1: Added multiplexed i2c bus 12
[    9.905102] i2c i2c-1: Added multiplexed i2c bus 13
[    9.910015] i2c i2c-1: Added multiplexed i2c bus 14
[    9.914811] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pc                                                           a9548
[    9.922658] i2c i2c-1: Added multiplexed i2c bus 15
[    9.927579] i2c i2c-1: Added multiplexed i2c bus 16
[    9.932498] i2c i2c-1: Added multiplexed i2c bus 17
[    9.937714] i2c i2c-1: Added multiplexed i2c bus 18
[    9.942634] i2c i2c-1: Added multiplexed i2c bus 19
[    9.947554] i2c i2c-1: Added multiplexed i2c bus 20
[    9.952477] i2c i2c-1: Added multiplexed i2c bus 21
[    9.957395] i2c i2c-1: Added multiplexed i2c bus 22
[    9.962191] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pc                                                           a9548
[    9.969765] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 34
[    9.976809] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    9.983600] rtc_zynqmp ffa60000.rtc: setting system clock to 2019-07-18 14:39                                                           :19 UTC (1563460759)
[    9.992521] clk: Not disabling unused clocks
[    9.996749] ALSA device list:
[    9.999656]   #0: DisplayPort monitor
[   10.003815] Freeing unused kernel memory: 512K
INIT: version 2.88 booting
[   10.089556] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data                                                            may be corrupt. Please run fsck.
Starting udev
[   10.126684] udevd[1916]: starting version 3.2.2
[   10.150658] udevd[1917]: starting eudev-3.2.2
[   10.221822] mali: loading out-of-tree module taints kernel.
[   10.255258] si5324 11-0069: si5328 probed
[   10.299927] si5324 11-0069: si5328 probe successful
Starting internet superserver: inetd.
Configuring packages on first boot....
 (This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-xserver-nodm-init...
Running postinst /etc/rpm-postinsts/101-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
INIT: Entering runlevel: 5
Configuring network interfaces... [   10.959794] pps pps0: new PPS source ptp0
[   10.963749] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
[   10.970384] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc (v1.24.1) started
Sending discover...
Sending discover...
Sending discover...
No lease, forking to background
done.
Starting system message bus: dbus.
Starting Dropbear SSH server: Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCIVTitAlj6y7pF1UfG8yVOhnMYNBLgRDC6zdJQXp56                                                           xFfQzZ6TVK4UdRdJGMs2WYGOYUuuYAT/PSjyPoGIzObjveX4iBCy9qsS8zkhJ8oaK4pXxFK2NvxIlC7L                                                           IkwhfrzA15zO+JioRr8TRckWZiijfwy+OOszJi2PVsQiXF17zv9+s/9BXH9+7D1EVlStfZ0jfNeQ8+Po                                                           Yp/dIwjNfHzEjuitzKpsrDWtFOZ1zMT9Vns7NRkgs7rjuRK57mFcI3PV9+F3hYpJLp3C0Ua5yJZVd4Fs                                                           mT9kO5z3GaezGswTz0J7cTAczYzyPjTOg2LQmZ5ZqRhRuWA8meRanmCsSUDj root@xilinx
Fingerprint: md5 f4:b1:73:85:89:ce:22:f6:d8:d3:91:03:d1:27:3a:d5
dropbear.
Starting syslogd/klogd: done
Starting tcf-agent: OK
Setting console loglevel to 0 ...
root@xilinx:~# ****************************************************
xauth:  file //.serverauth.2486 does not exist
xauth:  file //.Xauthority does not exist
Current Operating System: Linux xilinx 4.14.0-xilinx-v2018.2 #1 SMP Fri Jun 21 1                                                           7:29:23 CST 2019 aarch64
Kernel command line: earlycon clk_ignore_unused root=/dev/ram rw earlyprintk uio                                                           _pdrv_genirq.of_id=xlnx,generic-uio cma=1024M cpuidle.off=1 cpufreq.off=1
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 18 14:39:36 2019
To override, set QT_QPA_EGLFS_PHYSICAL_WIDTH and QT_QPA_EGLFS_PHYSICAL_HEIGHT (i                                                           n millimeters).
^C
root@xilinx:~# cat /var/l
lib/   local/ lock/  log/
root@xilinx:~# cat /var/log/Xorg.0.log
[    27.165]
[    27.165] X Protocol Version 11, Revision 0
[    27.165] Build Operating System: Linux 4.4.0-31-generic x86_64
[    27.165] Current Operating System: Linux xilinx 4.14.0-xilinx-v2018.2 #1 SMP                                                            Fri Jun 21 17:29:23 CST 2019 aarch64
[    27.165] Kernel command line: earlycon clk_ignore_unused root=/dev/ram rw ea                                                           rlyprintk uio_pdrv_genirq.of_id=xlnx,generic-uio cma=1024M cpuidle.off=1 cpufreq                                                           .off=1
[    27.165] Build Date: 21 June 2019  06:33:29PM
[    27.165]
[    27.165] Current version of pixman: 0.34.0
[    27.165]    Before reporting problems, check http://wiki.x.org
[    27.165] Markers: (--) probed, (**) from config file, (==) default setting,
[    27.165] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 18 14:39:36 201                                                           9
[    27.165] (==) Using config file: "/etc/X11/xorg.conf"
[    27.165] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    27.166] (==) ServerLayout "ServerLayout0"
[    27.166] (**) |-->Screen "DefaultScreen" (0)
[    27.166] (**) |   |-->Monitor "<default monitor>"
[    27.166] (**) |   |-->Device "ZynqMP"
[    27.166] (==) No monitor specified for screen "DefaultScreen".
        Using a default monitor configuration.
[    27.166] (**) Option "BlankTime" "0"
[    27.166] (**) Option "StandbyTime" "0"
[    27.166] (**) Option "SuspendTime" "0"
[    27.166] (**) Option "OffTime" "0"
[    27.166] (==) Automatically adding devices
[    27.166] (==) Automatically enabling devices
[    27.166] (==) Automatically adding GPU devices
[    27.166] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    27.166] (WW) The directory "/usr/share/fonts/X11/misc/" does not exist.
[    27.166]    Entry deleted from font path.
[    27.166] (WW) The directory "/usr/share/fonts/X11/TTF/" does not exist.
[    27.166] (WW) The directory "/usr/share/fonts/X11/OTF/" does not exist.
[    27.166] (WW) The directory "/usr/share/fonts/X11/Type1/" does not exist.
[    27.166] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    27.166] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    27.166] (==) FontPath set to:
[    27.166] (==) ModulePath set to "/usr/lib/xorg/modules"
[    27.166] (II) The server relies on udev to provide the list of input devices                                                           .
        If no devices become available, reconfigure udev or disable AutoAddDevic                                                           es.
[    27.167] (II) Loader magic: 0x5bfc00
[    27.167] (II) Module ABI versions:
[    27.167]    X.Org ANSI C Emulation: 0.4
[    27.167]    X.Org Video Driver: 23.0
[    27.167]    X.Org XInput driver : 24.1
[    27.167]    X.Org Server Extension : 10.0
[    27.167] (II) xfree86: Adding drm device (/dev/dri/card0)
[    27.169] (II) no primary bus or device found
[    27.169]    falling back to /sys/devices/platform/amba/fd4a0000.zynqmp-displ                                                           ay/drm/card0
[    27.169] (II) LoadModule: "glx"
[    27.170] (WW) Warning, couldn't open module glx
[    27.170] (II) UnloadModule: "glx"
[    27.170] (II) Unloading glx
[    27.170] (EE) Failed to load module "glx" (module does not exist, 0)
[    27.170] (II) LoadModule: "armsoc"
[    27.170] (II) Loading /usr/lib/xorg/modules/drivers/armsoc_drv.so
[    27.170] (II) Module armsoc: vendor="X.Org Foundation"
[    27.170]    compiled for 1.19.3, module version = 1.4.1
[    27.170]    Module class: X.Org Video Driver
[    27.170]    ABI class: X.Org Video Driver, version 23.0
[    27.170] (II) ARMSOC: Driver for ARM Mali compatible chipsets
[    27.170] (--) using VT number 2
[    27.171] (WW) Falling back to old probe method for armsoc
[    27.171] (II) No BusID or DriverName specified - opening /dev/dri/card0
[    27.171] (II) Got BusID fd4a0000.zynqmp-display
[    27.203] (II) Opened DRM
[    27.203] (II)    DeviceName is [/dev/dri/card0]
[    27.203] (II)    bus_id is [fd4a0000.zynqmp-display]
[    27.203] (II)    DriverName is [xlnx]
[    27.203] (II)    version is [1.0.0]
[    27.203] (II) Screen:0,  CRTC:-1
[    27.219] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    27.219] (II) ARMSOC(0): Creating default Display subsection in Screen secti                                                           on
        "DefaultScreen" for depth/fbbpp 24/32
[    27.219] (**) ARMSOC(0): Depth 24, (--) framebuffer bpp 32
[    27.219] (==) ARMSOC(0): RGB weight 888
[    27.219] (==) ARMSOC(0): Using gamma correction (1.0, 1.0, 1.0)
[    27.219] (==) ARMSOC(0): Default visual is TrueColor
[    27.219] (II) No BusID or DriverName specified - opening /dev/dri/card0
[    27.219] (II) Got BusID fd4a0000.zynqmp-display
[    27.253] (II) Opened DRM
[    27.253] (II)    DeviceName is [/dev/dri/card0]
[    27.253] (II)    bus_id is [fd4a0000.zynqmp-display]
[    27.253] (II)    DriverName is [xlnx]
[    27.253] (II)    version is [1.0.0]
[    27.253] (II) ARMSOC(0): Chipset: Mali
[    27.253] (**) ARMSOC(0): Option "Debug" "false"
[    27.253] (**) ARMSOC(0): Option "DRICard" "0"
[    27.253] (II) ARMSOC(0): Buffer Flipping is Enabled
[    27.253] (II) ARMSOC(0): umplock is Enabled
[    27.253] (II) ARMSOC(0): Setting the video modes ...
[    27.253] (II) ARMSOC(0): Adding all CRTCs
[    27.253] (II) ARMSOC(0): Got CRTC: 0 (id: 36)
[    27.274] (II) ARMSOC(0): Output DP-1 has no monitor section
[    27.295] (II) ARMSOC(0): EDID for output DP-1
[    27.295] (II) ARMSOC(0): Manufacturer: SAM  Model: c5b  Serial#: 810370100
[    27.295] (II) ARMSOC(0): Year: 2015  Week: 45
[    27.295] (II) ARMSOC(0): EDID Version: 1.4
[    27.295] (II) ARMSOC(0): Digital Display Input
[    27.295] (II) ARMSOC(0): 8 bits per channel
[    27.295] (II) ARMSOC(0): Digital interface is DisplayPort
[    27.295] (II) ARMSOC(0): Max Image Size [cm]: horiz.: 60  vert.: 34
[    27.295] (II) ARMSOC(0): Gamma: 2.20
[    27.295] (II) ARMSOC(0): DPMS capabilities: Off
[    27.295] (II) ARMSOC(0): Supported color encodings: RGB 4:4:4
[    27.295] (II) ARMSOC(0): First detailed timing is preferred mode
[    27.295] (II) ARMSOC(0): Preferred mode is native pixel format and refresh r                                                           ate
[    27.295] (II) ARMSOC(0): redX: 0.646 redY: 0.337   greenX: 0.328 greenY: 0.6                                                           15
[    27.295] (II) ARMSOC(0): blueX: 0.146 blueY: 0.056   whiteX: 0.313 whiteY: 0                                                           .329
[    27.295] (II) ARMSOC(0): Supported established timings:
[    27.295] (II) ARMSOC(0): 640x480@60Hz
[    27.295] (II) ARMSOC(0): 800x600@56Hz
[    27.295] (II) ARMSOC(0): 800x600@60Hz
[    27.295] (II) ARMSOC(0): 1024x768@60Hz
[    27.295] (II) ARMSOC(0): Manufacturer's mask: 0
[    27.295] (II) ARMSOC(0): Supported standard timings:
[    27.295] (II) ARMSOC(0): #0: hsize: 1280  vsize 720  refresh: 60  vid: 49281
[    27.296] (II) ARMSOC(0): #1: hsize: 1280  vsize 800  refresh: 60  vid: 129
[    27.296] (II) ARMSOC(0): #2: hsize: 1280  vsize 1024  refresh: 60  vid: 3289                                                           7
[    27.296] (II) ARMSOC(0): #3: hsize: 1440  vsize 900  refresh: 60  vid: 149
[    27.296] (II) ARMSOC(0): #4: hsize: 1600  vsize 900  refresh: 60  vid: 49321
[    27.296] (II) ARMSOC(0): #5: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[    27.296] (II) ARMSOC(0): Supported detailed timing:
[    27.296] (II) ARMSOC(0): clock: 148.5 MHz   Image Size:  598 x 336 mm
[    27.296] (II) ARMSOC(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_bla                                                           nk_end 2200 h_border: 0
[    27.296] (II) ARMSOC(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_bla                                                           nking: 1125 v_border: 0
[    27.296] (II) ARMSOC(0): Ranges: V min: 56 V max: 60 Hz, H min: 30 H max: 81                                                            kHz, PixClock max 175 MHz
[    27.296] (II) ARMSOC(0): Monitor name: S27E590
[    27.296] (II) ARMSOC(0): Serial No: HTQGB01735
[    27.296] (II) ARMSOC(0): EDID (in hex):
[    27.296] (II) ARMSOC(0):    00ffffffffffff004c2d5b0c34444d30
[    27.296] (II) ARMSOC(0):    2d190104a53c2278225295a556549d25
[    27.296] (II) ARMSOC(0):    0e505423080081c0810081809500a9c0
[    27.296] (II) ARMSOC(0):    b30001010101023a801871382d40582c
[    27.296] (II) ARMSOC(0):    450056502100001e000000fd00383c1e
[    27.296] (II) ARMSOC(0):    5111000a202020202020000000fc0053
[    27.296] (II) ARMSOC(0):    3237453539300a2020202020000000ff
[    27.296] (II) ARMSOC(0):    00485451474230313733350a202000a5
[    27.296] (II) ARMSOC(0): EDID vendor "SAM", prod id 3163
[    27.296] (II) ARMSOC(0): Using EDID range info for horizontal sync
[    27.296] (II) ARMSOC(0): Using EDID range info for vertical refresh
[    27.296] (II) ARMSOC(0): Printing DDC gathered Modelines:
[    27.296] (II) ARMSOC(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 22                                                           00  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    27.296] (II) ARMSOC(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  6                                                           00 601 605 628 +hsync +vsync (37.9 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  6                                                           00 601 603 625 +hsync +vsync (35.2 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "640x480"x0.0   25.18  640 656 752 800  48                                                           0 490 492 525 -hsync -vsync (31.5 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 134                                                           4  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "1280x720"x60.0   74.48  1280 1336 1472 16                                                           64  720 721 724 746 -hsync +vsync (44.8 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "1280x800"x0.0   83.50  1280 1352 1480 168                                                           0  800 803 809 831 -hsync +vsync (49.7 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 16                                                           88  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 190                                                           4  900 903 909 934 -hsync +vsync (55.9 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 21                                                           28  900 901 904 932 -hsync +vsync (55.9 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 22                                                           40  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[    27.296] (II) ARMSOC(0): Printing probed modes for output DP-1
[    27.296] (II) ARMSOC(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2                                                           200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    27.296] (II) ARMSOC(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2                                                           240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "1600x900"x60.0  108.00  1600 1624 1704 18                                                           00  900 901 904 1000 +hsync +vsync (60.0 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1                                                           688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 19                                                           04  900 903 909 934 -hsync +vsync (55.9 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 16                                                           80  800 803 809 831 -hsync +vsync (49.7 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 16                                                           50  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 13                                                           44  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "800x600"x60.3   40.00  800 840 968 1056                                                             600 601 605 628 +hsync +vsync (37.9 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "800x600"x56.2   36.00  800 824 896 1024                                                             600 601 603 625 +hsync +vsync (35.2 kHz e)
[    27.296] (II) ARMSOC(0): Modeline "640x480"x59.9   25.18  640 656 752 800  4                                                           80 490 492 525 -hsync -vsync (31.5 kHz e)
[    27.296] (II) ARMSOC(0): Output DP-1 connected
[    27.296] (II) ARMSOC(0): Using exact sizes for initial modes
[    27.296] (II) ARMSOC(0): Output DP-1 using initial mode 1920x1080 +0+0
[    27.296] (II) ARMSOC(0): Got KMS resources
[    27.297] (**) ARMSOC(0): Display dimensions: (600, 340) mm
[    27.297] (**) ARMSOC(0): DPI set to (81, 80)
[    27.297] (II) Loading sub module "dri2"
[    27.297] (II) LoadModule: "dri2"
[    27.297] (II) Module "dri2" already built-in
[    27.297] (II) Loading sub module "exa"
[    27.297] (II) LoadModule: "exa"
[    27.297] (II) Loading /usr/lib/xorg/modules/libexa.so
[    27.297] (II) Module exa: vendor="X.Org Foundation"
[    27.297]    compiled for 1.19.3, module version = 2.6.0
[    27.297]    ABI class: X.Org Video Driver, version 23.0
[    27.297] (II) Loading sub module "fb"
[    27.297] (II) LoadModule: "fb"
[    27.297] (II) Loading /usr/lib/xorg/modules/libfb.so
[    27.297] (II) Module fb: vendor="X.Org Foundation"
[    27.297]    compiled for 1.19.3, module version = 1.0.0
[    27.297]    ABI class: X.Org ANSI C Emulation, version 0.4
[    27.297] (--) Depth 24 pixmap format is 32 bpp
[    27.300] (II) ARMSOC(0): Soft EXA mode
[    27.300] (II) EXA(0): Driver allocated offscreen pixmaps
[    27.300] (II) EXA(0): Driver registered support for the following operations                                                           :
[    27.300] (II)         Solid
[    27.300] (II)         Copy
[    27.300] (II)         Composite (RENDER acceleration)
[    27.300] (II) ARMSOC(0): Setting swap chain size: 2
[    27.300] (II) ARMSOC(0): [DRI2] Setup complete
[    27.300] (II) ARMSOC(0): [DRI2]   DRI driver: armsoc
[    27.300] (==) ARMSOC(0): Backing store enabled
[    27.300] (==) ARMSOC(0): Silken mouse enabled
[    27.300] (II) ARMSOC(0): HW cursor init()
[    27.319] (II) ARMSOC(0): RandR 1.2 enabled, ignore the following RandR disab                                                           led message.
[    27.320] (--) RandR disabled
[    27.320] (II) ARMSOC(0): Setting screen physical size to 508 x 285
[    27.435] (II) config/udev: Adding input device gpio-keys (/dev/input/event0)
[    27.435] (**) gpio-keys: Applying InputClass "evdev keyboard catchall"
[    27.435] (**) gpio-keys: Applying InputClass "libinput keyboard catchall"
[    27.435] (II) LoadModule: "libinput"
[    27.435] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    27.436] (II) Module libinput: vendor="X.Org Foundation"
[    27.436]    compiled for 1.19.3, module version = 0.25.1
[    27.436]    Module class: X.Org XInput Driver
[    27.436]    ABI class: X.Org XInput driver, version 24.1
[    27.436] (II) Using input driver 'libinput' for 'gpio-keys'
[    27.436] (**) gpio-keys: always reports core events
[    27.436] (**) Option "Device" "/dev/input/event0"
[    27.436] (**) Option "_source" "server/udev"
[    27.437] (II) event0  - (II) gpio-keys: (II) is tagged by udev as: Keyboard
[    27.437] (II) event0  - (II) gpio-keys: (II) device is a keyboard
[    27.437] (II) event0  - (II) gpio-keys: (II) device removed
[    27.468] (**) Option "config_info" "udev:/sys/devices/platform/gpio-keys/inp                                                           ut/input0/event0"
[    27.468] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOA                                                           RD, id 6)
[    27.469] (II) event0  - (II) gpio-keys: (II) is tagged by udev as: Keyboard
[    27.469] (II) event0  - (II) gpio-keys: (II) device is a keyboard
Mentor watari
Mentor
Hi @xiaomengmiao
Since display area on Samsung S27D590 is different with your setting, linux output this message.
Please make sure specifications of your monitor.
- Pixel/Diplay Area from manual
597.9 mm (H) x 336.3 mm (V)
23.5 inches (H) x 13.2 inches (V)
Best regards,
