jayantbala
Alternative for FX2 100SA 1.27R ?
Hi all ,
          I am using a S3A starter kit .It is having a Hirose make FX2 100p-1.27DS connector .I need a cable receptor for this connector. While searching i found Hirose make FX2 BA 100SA-1.27R female connector.But unfortunately this connector is not available with Farnell and RS componets in India. Can anyone pls tell me any alternative connector for the same from Tyco or other make.
thank you in advance.
Tags (2)
johnsj73
i am also in need of the same connector, plz let us share how we are going to overcome this problem.
also how will u know which pin corresponds to which ucf constrain?
learner1
Yes I think it is really important (for me because I may use it to communicate with FPGA and outer ADC board ) to know which pin of the Hirose FX2 extension connector corresponds to which signal in the UCF . When I look to the Hirose expansion connctor on Spartan 3AN I saw two the two layers are seperated with A and B . Are they the signals named A4 for example in the user guide  ?
Any suggestion or help ?
HIDIR
johnsj73
I got the connector from mouser.com. Their part no. is 798-fx2100s127dsl71. Pin no. 1 of the male is the top right pin and pin 1 of female is top left pin when the connectors are facing u.
