Artix7A100 vs Zynq-2020
Hello
As both Artix7A100 and Zynq-2020 has approximatly the same resource size, do the dual ARM cores of the Zynq-2020 make it practically superior and can fit larger applications?
Scholar u4223374
Re: Artix7A100 vs Zynq-2020
The ARM cores have no effect whatsoever on the programmable logic resources. If a design won't fit on the XC7A100T, it won't fit on the XC7Z020 either.
The ARM cores do mean that you get a powerful processor (more powerful than you could easily implement in the FPGA fabric) for free (ie no resources used), along with all of its peripherals (memory controller, USB, network, etc). Most of these can only be accessed by the ARM cores; you can't get to them from the FPGA fabric directly. The processor can also simplify some tasks; for example Zynq chips can boot from an SD card, whereas the Artix chips require separate flash memory.
On the other hand, the XC7Z020 has a somewhat smaller FPGA fabric than the XC7A100T, it costs more (not much more, but still), it has more limited package options, and it has no high-speed transceivers.
As a general rule, if you were going to include a processor anyway (eg. MicroBlaze) then get the Zynq. If you're doing a pure FPGA design, stick with the Artix.
Scholar u4223374
