Aurora Loopback on ZC706 board
I am relatively new to Aurora cores, and IP integrator.
I have been trying to replicate the "xapp1192" on ZC706 board. I could get the second example to work smoothly  (internal loopback -- PCS and PMA) but for the first example, I had to modify the design because of the lack of two boards. Following is my scenario:
1) ZC706 board
2) FMC board (HTG-FMC-CX4-SATA-SMA)
I plan to complete the external loopback using two different clocks (one from SMA and one from FMC-LPC). So, I am using IP integrator to customize and instantiate two different Aurora (64B/66B) cores. While customizing the cores, I am a little puzzled I plan to use the GTX_BANK_111 which enables both FMC_LPC and SMA clocks as the MGT reference clocks.
How do I address the rest of the clock signals of the core (like sync clk, usr clk...)?
Thanks in advance.
S
Community Manager
Community Manager
Re: Aurora Loopback on ZC706 board
drp_clk_in can be common for both master and slave and it can come from external source.
Krishna
I believe you are trying to create a design with 2X1 lane design. If the core configuration is same with both single lane design, you should create
one of the core with "Shared logic in core" -- master
second core with "Shared log in example design" -- Slave
the clocks -- sync_clk, usr_clk will be generated by master and can be connected to slave.
Thanks for feedback. Indeed, I am trying to create a 2X1 lane design.
I could connect the master "clk_out" to the relevant "clk_in" but I want to drive the slave interface with a different GT_DIFF_REFCLK. Is that possible, having this configuration? This is to replicate the different SMA clock on the other board of the example, which I plan getting around using the FMC_LPC clocks on J5, namely (MGTREFCLK0P_111 and MGTREFCLK0N_111).
I hope this design choice is not absolutely absurd?
Thanks in advance.
Yes. It is possible to apply different REFCLKs to the Master and Slave cores.
The use case is proper one only.
How to address "drp_clk_in" ?
Community Manager
Community Manager
Krishna
