eceyang
BPI FLASH for user data storage on ML605
I intended to use the BPI FLASH for user data storage on ML605. Can I just treat the flash as a normal NOR FLASH? Does it need special attention when designing the FLASH controller? It seems the chip works in asynchronous mode since CLK is tied to '1' and ADV# is tied to '0'.
kkn
check the following link for the application note which you can check the Programming state machine part for bpi flash writing
http://www.xilinx.com/support/documentation/application_notes/xapp518-isp-bpi-prom-virtex-6-pcie.pdf
