pourrad
Bluecat linuxon SP3E based on UG258
I'm trying to use ug258 that implements an embedded system with bluecat linux. UG258 is based on xilinx ISE and XPS 9.2. I'm using the current version of the tools (11.3).
When I use XPS to open the project file, it starts updating it, but can't find some of the components because they are older versions and for some of the it says that the new versions are not compatible with the older ones.
Is there any documents or recommended steps that I can follow for porting UG258 reference design into version 11.3 of the Xilinx tools?
tushar_dongre
You can follow the MHS file and select the components of reference design available with UG258 to build the design with EDK11.3.
