Hi all,
   I want to add my own board in vivado,so how do I generate the board of the XML document.
Re: Board
Hi @zitengxiaxiang,
You can contact the distributor for the board files from whom you bought your board.
In case you want to create  a new one please go through Appendix-A (page101-123) of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug895-vivado-system-level-design-entry.pdf
Arpan
Re: Board
check these links
https://forums.xilinx.com/t5/Xilinx-Boards-and-Kits/Adding-a-board-to-a-device-in-Vivado/td-p/812958
https://reference.digilentinc.com/learn/software/tutorials/vivado-board-files/start?redirect=1
Thanks and Regards
Balkrishan
Re: Board
Hi @zitengxiaxiang,
Arpan
