CF load problem on xupv5-LX110T
I have a Xilinx xupv5-LX110T Evaluation Platform ready for openSPARC that comes with a 1Gb CF card.
My Compact Flash card is no longer in it's original state and I can not load .ace files: the System Ace error LED remains solid red.
I have then copied to my CF the files provided on http://www.xilinx.com/univ/xupv5-lx110t-bsb.htm  (Stand-Alone Applications & Board Tests), which where the same files I had, but it steel does not work.
Then reading the documentation I understood I need to restore the image of the card (Is that correct?). But the images are only available for ML505, ML506 and ML507.
How can I restore my CF?
