mugundhaniia
CPLD Reconfiguration
I need to use PCI express on my XUPV5 board for which I reconfigured my CPLD as per this answer record http://www.xilinx.com/support/answers/43175.html. Will this reconfiguration last on Power On-Off cycles ? If no, how do I make this configuration stay permanantly ?
Thank you,
u4223374
Advisor
Advisor
CPLDs are non-volatile, so it'll retain the configuration when powered-off (and continue to do so until you reprogram it with a different bitstream).
u4223374
Advisor
Advisor
