scwoo80
Cable connection failed...W​ARNING:iMP​ACT:923 - Can not find cable, check cable setup !
Hi again
I'm using ISE 10.1 License version & XC3S4000(Opal Kelly XEM3050 USB Board) & Window7 32bit
I did generate bit file but I got a cable connection failed error like below
case 1. Cable Auto Connect
case 2. Initialize Chain
How can I fix it?
Thanks in advance
GUI --- Auto connect to cable...
// *** BATCH CMD : setCable -port auto
AutoDetecting cable. Please wait.
PROGRESS_START - Starting Operation.
Connecting to cable (Parallel Port - LPT1).
Checking cable driver.
 Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811.
Connecting to cable (Parallel Port - LPT2).
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
Connecting to cable (Usb Port - USB21).
 Source driver files not found.
The Platform Cable USB is not detected. Please connect a cable.If a cable is connected, please disconnect
and reconnect to the usb port, follow the instructions in the 'Found New Hardware Wizard', then retry
the Cable Setup operation.
Connecting to cable (Usb Port - USB22).
Connecting to cable (Usb Port - USB23).
Connecting to cable (Usb Port - USB24).
PROGRESS_END - End Operation.
Elapsed time =      2 sec.
Cable autodetection failed.
2. Initialize Chain
Elapsed time =      3 sec.
WARNING:iMPACT:923 - Can not find cable, check cable setup !
mcgett
There are two likely conditions that are causing your problem.
   1) The ISE 10.1 software does not support Windows 7, you will need to upgrade to 12.3 for support
   2) You have connected directly to the USB port on the XEM3050 and this can not configure the PROM or FPGA.
          - You need a Xilinx JTAG cable either the PC-IV or USB.
Also, this should be in the "3rd Party/Other Boards and Kits" as the XEM3050 is not produced by Xilinx.
Anonymous
Not applicable
Windows 7 isn’t officially supported until ISE tools version 13.1. You can find more details in http://www.xilinx.com/support/answers/35072.htm
However, I believe most core functions should work with Windows 7 in case of ISE12.3 tools
v_tihhomirov
I also use Xilinx 10. The cable works in ISE but not in EDK (though I installed EDK with drivers)!
tmcdowe
this space intentionally left blank
v_tihhomirov
For EDK cables, I downloaded the Virtual Machine and ran WinXP. Though, it is slow and does not support SDRAM anyway (despite of tha claims that EDK 10.1 sp3 must do it).
