Can I use differential HSTL 1.2 V to drive LVDS?
hi,
i want to connect mipi camera via FMC connector in the Xilinx ZCU106 EVB (w MPsoc Uscale+).
in order to do so, i need to configure the FMC voltage banks to 1.2V (FMC_Vref). this is why i have this 1.2V limitation...
i also need to output via the FMC connector Camera link, meaning using LVDS.
can i use diff HSTL 1.2V from the MPSoC to drive LVDS (actually, the diff HSTL will drive an LVDS cable driver reciver - DS25BR440).
thanks
What you need to do is check :
   the transmiter has a V0h and VoL max and min
      the receiver has VIh and VIl max and min,
Look here for TTL as an example
https://www.allaboutcircuits.com/textbook/digital/chpt-3/logic-signal-voltage-levels/
You draw two vertical  lines like in the first diagram,
     add to that the range that the transmiter can drive over , and the reciver can receive over,
         if the two overlap , like in the picture, then you have a workign system,
Remeber the termination, as its differential and fast
