Observer lpandlly
Can I use ethernet to transmit a data file?
hi, I tried to transmit a data file from PC to the XUP board. However, I can't find any example code or documents to tutor myself.
Would you help me?
Thank you previously!
Visitor jatxl3
Re: Can I use ethernet to transmit a data file?
We also try to transfer data from PC to 3s400 FPGA,
the first step we take is to config the IP address of  MAC CS8900A,
then try to Ping this MAC from PC,
if MAC address is config right, the Link Led on development board will flash.
Observer lpandlly
I really thank you for sharing your experience with me. However, I can't get the code of transmit the file from the pc to xup board, althought I have known the steps to connect the pc and board through the ip address. I'm not sure if there is any example online so that we can refer to them and compile our own application code.
Thanks again.
