Visitor otters
Can XC5VLX330 be replaced by XC6VLX760?
Hello all!
Since the packages of XC5VLX330 and XC6VLX760 are exactly the same, both are FF1760, can I replace the XC5VLX330 on our board with XC6VLX760 without modifying the PCB layout?
Would there be any problems?
Thanks!
Re: Can XC5VLX330 be replaced by XC6VLX760?
    Although packages are compatible, the pinouts of the two devices are not compatible. It is not possible to replace the Virtex-5 device with a Virtex-6 device. Within a device family(Virtex-6 or Virtex-5), it is possible to migrate between certain devices after taking necessary precautions.
Praveen
Praveen
Visitor otters
OK, thank you!
