Visitor mtde
Can't Capture correct data from ADC's serial LVDS output using High Speed Select I/O
Currently, we are bringing up a new board with AD9653+Xilinx ZYNQ Ultrascale+. We can’t capture correct data from AD9653 serial LVDS.
Problem description:
Bit clock @ 400MHz: We can get correct data both in test pattern mode and normal working mode.
Bit clock @1GHz: We captured an unexpected 1 bit or 9 bits data when switched from test pattern mode to normal working mode.
Re: Can't Capture correct data from ADC's serial LVDS output using High Speed Select I/O
I'm glad to hear you're up and running! Please mark your Solution as Accepted, to benefit other users.
Thanks for the update!
Andres
Hi mtde,
Which Xilinx Evaluation Board are you using?
How are you connecting the ADC to the Xilinx Eval Board?
Andres
Visitor mtde
Hi Andres, Thanks for your support. We connected the ADC board to Xilinx ZYNQ Ultrascale+ Eval board by FMC connector. This issue has been solved when we changed MSB first to LSB first. Sincerely, LB Shi
Andres
