11-06-2018 07:34 AM - edited 11-06-2018 07:35 AM
Hi there,
The point is that I am not capable of completing the Quick Start Guide of ZCU106 evaluation Kit. When I set the SW6 according to the way shown in the guide (On, Off, On, On), I am getting these two red lights, and as you see in the attached picture, the DONE led is glowing neither red nor green.
I have been reading many related posts where people talk about Power conctroller configuration failures and so on, but according to a Xilinx post my ZCU106 device shouldn't be affected since its S/N data mark is later than 1830 (it is 1832 btw).
How can I solve this issue so that I can pass the BUilt-In Self-Test?
thank you in advance.
11-06-2018 12:51 PM
Hi @jolaizolaa,
In your case PS_ERR_OUT Led is RED because DS9 (MGTAVTT) and DS13 (MGTAVCCAUX) voltage rails are not powered or inactive. MAX8869E Power regulator is failing. Thats the reason BIST is failing.
1. are you facing this issue at time 0 or after some usage?
2. are you facing this issue in this single board or multiple boards?
3.please share the Serial number and revision version of the board.
4.Is the board under warranty? If yes, Please share the Purchase order and Shipping order document.
For More information on warranty of board Please refer AR#45432.
5. if the board is not under Warranty, Please contact Whizz Systems are our contract manufacturer and official Xilinx Design Partner.
11-06-2018 12:51 PM
Hi @jolaizolaa,
11-06-2018 01:14 PM
11-06-2018 10:58 PM
Hi @jolaizolaa,
if the board is under warranty, You can apply for RMA if there have been no unofficial or non recommended changes were done to this board.
Deepak D N
Please Reply or Give Kudos or Mark it as an Accepted Solution.
