Cannot connect ZC702 and XM105
I try to use XM105 for debugging  the signal from ZC702 evaluation borad. I connected XM105 to ZC702 shonw as attachedment. Aftert XM105 connection, I cannot open device from vivado. However, disconnecting XM105, I can open device.
Is there any setting for connectiong XM105?
The three good leds on XM105 is lighted.
After connecting XM105
Before connecting XM105:
Hi @ura_hiro
Can you please check jumper settings at J5 of XM105 board? Make sure TDO, TDI pins are connected through jumper.
Rohit
Hi @ura_hiro ,
I checked at my end, JTAG Chain was established when i plugged XM105 Card on HOPC and LPC Connectors of ZC702 Board.
There is no extra setting you need to do when you connect FMC Card to ZC702 Board. When an FPGA mezzanine card (FMC) is attached to J3 or J4 it is automatically added to the JTAG chain through electronically controlled single-pole single-throw (SPST) switches U25 and U26. The SPST switches are normally closed and transition to an open state when an FMC is attached. Switch U25 adds an attached FMC to the JTAG chain as determined by the FMC1_HPC_PRSNT_M2C_B signal. Switch U26 adds an attached FMC to the JTAG chain as determined by the FMC2_LPC_PRSNT_M2C_B signal The attached FMC card must implement a TDI-to-TDO connection using a device or bypass jumper to ensure that the JTAG Chain connects to FPGA present on ZC702 Board.
Can you confirm once Jumper settings are fine by referring this ZC702 Debug Checklist ?
Is XM105 card is working in another board ? So that we can eliminate issue with FMC Card.
After attaching the FMC Card, Try slowing the TCK Frequency to 3 MHz and let us know if the JTAG Chain is established(share the snapshot). For more information on reducing the TCK Frequency refer page 36 of UG908 (v2019.2).
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Hi ddn,
Thank you for your advices. However, I couldn't resolove problem yet.
I checked the jumper pin. Jumpper pin is same as Default Jumper Settings.
I changed both XM105 and ZC702 board. The result is not changed.
I opened Open Harware Tagert and select Local Server shown as attached picture. But there is no list in Hardware Devices. I cannot set the 3MHz for connect. Is there wrong?
Addtionally, I connected the FMCOMMS3 to ZC702 for checking FMC interface. FMCOMMS3 is works well.
BRs,
Hiroyuki
Hi @ura_hiro
Rohit
Hi Rohit,
Thanks you for your help. I could resolve the problem by your reponse.
BRs,
Hiroyuki
