Clocking wizard for SP601
Hi there!
I have just acquired a Xilinx SP601 Eval board and have received the ISE software ver. 11.3 with the same. I am going through the In-depth tutorial of the ISE but am stuck at one point. In the 'Creating a DCM Module' section, I need to use the Clocking wizard. In that when I select FPGA Features and Design > Clocking, I cannot find the clocking option for the Spartan 6 board in the software.
Could someone help me as to what values are needed to be changes so that I can use this module on my Spartan 6 board. Can I directly use the FPGA Features and Design > Clocking > Clocking Wizard. ?? If so, what values do I need to change?
Jack
Advisor joelby
Advisor
Re: Clocking wizard for SP601
How far did you get with the clocking generator? It will do everything you want, other than deciding what to do with the 100 MHz signal - that's where you come in.
If you need to forward it to an external pin, use an ODDR2 clock forwarding scheme. Have a look in the language templates for details about ODDR2.
Depending on your needs, you may also be able to just use the 200 MHz system clock with a divider to produce a 100 MHz output.
Advisor joelby
Advisor
Yes, just use Clocking Wizard.
You'll need to correctly set the input clock frequency based on the SP601 clock you wish to use (I think you've got a couple to choose from). The SP601 manual will tell you what the clocks are, which pins they're present on, and if they're single-ended or differential.
Thanks a lot there joelby!
I now need to generate a simple square signal of 100 Mhz using the FPGA. I tried looking for any simple programs but to no avail!!!
Any help???
Jack
Advisor joelby
Advisor
Wooohooo!!!! I've done it!!!
Thank you thank you thank you Joelby!
Advisor joelby
Advisor
Excellent! I'm glad you sorted it out :)
I have managed to generate the required signal as instructed and have got the output both at the SMA connector as well as the LEDs on the SP601 board (the code is attached). Now I have an FMC XM105 debug card and I want to select one of the pins on the debug card as my output. I wanted to get the output on the LEDs on the FMC board.
I checked the Pin connections and the LED corresponds to the following pin connections:
FMC connector J17 pin G37 corresponds to the LED DS1 on the board.
Checking the FMC LPC Pin Connections of the SP601 board, I found out that this pin (G37) corresponds to the (N9) pin on the FPGA board.
Now when I connect my output to the (N9) pin on the board, I should be getting the output on the FMC card, right? But that's not the case! I am not getting any output on the FMC board. The XM105 card is working properly (I hope), since on Power Good LEDs i.e. DS5, DS6, DS7 are on.
Are there some more steps to configure the XM105 board? I even tried changing the Jumper setting J4 on the SP601 board (in which it says to include FMC) but then I got an error while downloading the program on the board. The ISE iMPACT window gave an error "Program Failed" in that case.
What do I do??
Advisor joelby
Advisor
J4 is used to route the JTAG chain via the FMC LPC port. It's only necessary if your FMC card contains additional JTAG devices that you want to put in the chain.
Pin N9 looks like it's correct. Are you sure the LED is not working correctly? Have you probed it with a fast oscilloscope? (at least 100 MHz, since you're just checking for the existence a 100 MHz signal)
If you're toggling an LED at 100 MHz with a 50% duty cycle, perhaps you just can't see it lighting up. Start small, with a 1 Hz pulse, or just assign the LED output to '1' or something.
Hi there again Joel!
I've been trying many different permutations and combinations with my signal and have been steadily increasing the frequency from 20MHz up to 400MHz.
The only problem is that the signal starts degrading as the frequency increases. Up until 20MHz, I get a proper square wave with a 50% duty cycle. Thereafter the wave starts getting more and more noisier. After 100 MHz I cant see any square wave anymore, it simply becomes a sine wave. Why is that??
Also, how do I counter that effect? I need a clean signal at least until 100MHz wherein I get a clean square wave without much percievable noise.
I am taking the output at Pin H18 of the SP601 which corresponds to the SMACLK_N on to the oscilloscope. Have attached my program for reference.
Jack
Instructor
Instructor
Are you using an oscilloscope to probe your signal?
If you want to measure a 100MHz digital signal with a 'scope, the scope and probes should be rated for at least 350MHz bandidth.  A 1GHz scope will give you more accurate measurements than a 350MHz scope, but 350MHz should be (barely) adequate.
A 100MHz scope (and probes) is entirely inadequate for measuring or displaying amplitude, risetime, shape (e.g. ringing or reflections) or duty cycle of a 100MHz digital signal.
-- Bob Elkind
SIGNATURE:
Summary:
Yes I am using a 500MHz,1GSa/s,4ch scope (Tektronix TDS540). So I dont really think that the problem lies with the Scope. Even with 50MHz. the signal shows significant noise on the upper and lower crests of the signal.
Does the FPGA change the characteristic of the signal with the increase in frequency??
Instructor
Instructor
Do you have the probes properly GNDed to a point very near the signal being probed?
You have the scope's vertical BW limit disabled, yes?
1.  zoom scale to barely fit a single rising edge in the first 3 horizontal divisions, and barely fit vertically.
2.  without changing H or V scale, grab photos of a 100MHz signal rising edge and a 20MHz (or so) rising edge.
Let's compare displayed waveforms with all scope settings and displays equal.
-- Bob Elkind
SIGNATURE:
Summary:
The Probe is an SMA probe and hence I don't think that grounding is the issue. Have attached the pics as you wished!
50 MHz.
100 MHz.
100 MHz. at 10GS/s
Now you see the problem!!!
How do I get around this??
Instructor
Instructor
Turn on the 50 ohm termination in the scope's Vertical menu > DC Coupling selections.
You are probing half of a diff pair.  What is the output drive (IOSTANDARD selections) from the FPGA?
What differences do you see with real-time sampling instead of equivalent time sampling?
The crappy waveforms look like the results of a poorly grounded scope probe or a poorly terminated signal (which this is).
I assume the coax between the SMA connector and the scope is 50-ohm (and not 75-ohm), yes?
And the cable is roughly 18-24 inches long?
-- Bob Elkind
SIGNATURE:
Summary:
OK! I turned on the 50 ohm termination in the scope's selection and yes my waveform did improve dramatically. Thanks a lot for that Bob!
And yes you are right again, I am using a 50 ohm coax (RG- 58) instead of the 75 ohm one. Also it is around 2 m or 78 inches. I know these are quite silly mistakes and I hope you aren't too mad at me for this!!!
Also, I understood what you meant by half a differential pair. But what did you mean by IOSTANDARD selections of the FPGA? Are you talking about the standard I/Os available to the user by SP601? According to the manual, there are 5.
1. LED's
2. DIP switch
3. Push Button switch
4. CPU Reset pushbutton switch
5 GPIO male pin header
Of these, I tried taking the output at the LED's but since the space is too tiny for the probe and the ground, my readings were inconsistent!
I think I should get a better reading with a 75 ohm cable, right?
Thank you for the help though! Really appreciate it!
Instructor
Instructor
Not even close.
For each IO pin you can select from a wide range of signaling standards.  The voltage levels vary, and (for outputs) the output drive current can vary.  For Spartan-6 family, these IO options are listed in DS162, Tables 7, 8, 9, and 10.
It's way more complicated than that.  You need to study up on transmission line principles and circuit board layout concepts.  You are clearly not (yet) a hot-shot circuit board designer.
I'm too tired from an all-nighter to expound on transmission line theory right now, but that's the simple category of your problem.  Another label for your type of problem is "signal integrity".  What it comes down to is this:
  • under certain conditions, you can just hook up outputs and inputs with simple wires.
  • under other conditions, you must "manage" the interconnect so that signal reflections (yes, the signals bounce off of load pins like billiard balls on a pool table, sometimes right side up and sometimes upside down) don't cause the system to crash and burn.
Make sure you switch the scope input back to 1MegOhm when you are using a normal everyday passive scope probe instead of coax.
You are very welcome.  Grab a hold of a board designer, and ask him/her what "transmission line" means.  You may need to buy lunch.
-- Bob Elkind
SIGNATURE:
Summary:
Instructor
Instructor
cell phone photos
This is completely off-topic, but...
You did OK with the photos from your Samsung model GT-S5620 cell phone.  If you want your photos to be a bit sharper, try bracing or supporting your hand -- or the phone -- with something more solid.
The "shutter speed" for the photos was 1/8 second.  That's long enough time for your hand to twitch or move, and that caused blurring in the photos.  In the last photo, you can see the scope trace smear from left to right.
So, if you're interested in sharper photos, rest your hand or cell phone on a stack of books or something, to help keep the camera/phone steady.  If you are already resting the phone to steady it, keep practicing your technique.  Perhaps bracing the camera/phone from behind, as well as from below, would help.
Thanks for indulging me...  :)
-- Bob Elkind
SIGNATURE:
Summary:
Instructor
Instructor
forensic analysis
I've taken two of the scope traces you posted and marked them up for illustration -- forensic analysis, if I'm allowed to be pretentious.  One trace is supposed to be "clean", and a higher-frequency trace is inexplicably corrupted.
The evidence suggests otherwise, and is quite consistent.  Take a look at the two traces:
The slow, clean signal is on top.  The 50MHz deranged signal is below.
Here's the breakdown...
  • Signal hits the "infinite" impedance of the scope input, and a 100% amplitude positive reflection travels back toward the FPGA
  • At the FPGA, the apparent impedance of the output circuit is lower than the 50-70 ohm circuit board transmission line impedance, resulting in a ~25% amplitude negative reflection back to the 'scope
  • The reduced amplitude, inverse reflection hits the scope input roughly 23nS after the initial signal edge
  • If the round-trip transit time is ~23nS, the one-way trip between FPGA and 'scope is ~11.5nS.  At 1.8nS per foot, this corresponds to roughly 6.3 foot long transmission line length.  This is close to the reported 2m coax cable length plus some circuit board trace length.
It all fits.
The scope traces are marked at the midpoint of a waveform edge and at the midpoint of reflected signal edge -- after the round trip from scope to FPGA and back.
The supposedly "clean" waveform is only "clean" because the reverse reflection of the rising signal edge is roughly coincident with the falling edge of the unreflected signal.  When you know what to look for and where to look, the 'hitch' in the falling edge of the trace is clear.  The 'hitch' is the effect of the reflection.  If the period of the lower frequency signal was 20nS longer, the effects of the reflection would have been as clear as it is in the 50MHz waveform.
In both waveforms, the reflection is roughly -25% of the original signal amplitude.  If the SP601 board trace impedance is ~50 ohms, a -25% amplitude reflection suggests a ~30 ohm FPGA output driver impedance.  The reflection coefficient is calculated by this equation:
 Zterm - Z0
------------- = ρ
 Zterm + Z0
Does this make sense to everyone?  I hope this helps illustrate how a "good" set of scope measurements can obscure problems rather than reveal them.
Comments, suggestions, and corrections are welcome.
-- Bob Elkind
SIGNATURE:
Summary:
Re: forensic analysis
Hail BOB!!!!!
Mannn!!! Once you bite in, you sure don't let go, do you? Not that I'm complaining! I cant really thank you enough for the complete explanation of the topic that you have give here. I'm still going through the entire write up now.
N ya, thanks for the lesson on 'Photography of Signals, for Dummies' Should help me immensely next time I do something of this sort!
Jack
Instructor
Instructor
Well... yes, to a point... occasionally...  I must confess you made the opportunity, by providing a classic test case and a very nice set of example scope trace photos.  All I needed to add was the text and a little bit of red-pen marking.
Remember, this was an explanation of a problem, and nothing more.  You still have an "action item" to learn transmission line concepts, as applied to circuit board traces.  This is essential stuff for hardware engineers.
If you liked that little bit, you should like this massive discourse proportionately more.  :)
-- Bob Elkind
SIGNATURE:
Summary:
