Configuring Kintex ultrascale FPGA with QUAD SPI NOR Flash. Combining bit and Elf file.
Re: Configuring Kintex ultrascale FPGA with QUAD SPI NOR Flash. Combining bit and Elf file.
Hi selvakumarg@bel.co.in ,
I belive you are using Microblaze in your design.
Please use updatemem command to merge a bit and an ELF file. For more information refer Chapter 7 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug898-vivado-embedded-design.pdf.
Hope this helps.
Deepak D N
Please kudo and Accept as a Solution, If it helps.
