Narasimha
Constraints
How can I get master xdc files for ZYNQ-7000 board
joancab
Advisor
Advisor
You don't get a constraints file per chip or per board. You make your own constraints per project.
Here is the Constraints User Guide
Some constraints, like pin location and interface depend on the board and some evaluation boards provide an example constraints file with their documentation.
But that's not all. You may want to change some locations or standards, so better if you actually know how to make and modify them.
Then there are timing constraints, these are completely project-specific and essential to know.
florentw
Hi @Narasimha
What is the board? ZYNQ-7000 is a devices family. There a multiple boards based on this device like from Xilinx there is the ZC702 and ZC706.
Narasimha
I actually wanted for z010clg400-1 or z020clg400-1 FPGA configurations
kdeshwal
Hi @Narasimha ,
Xilinx provide XDC file for only Evaluation boards.
For custom boards, User needs to create their own constraint files (xdc) based on interface and voltage compatibility with other peripheral in the system.
You can refer to the pinout file for reference.
https://www.xilinx.com/support/package-pinout-files/zynq7000-pkgs.html
Kuldeep
Please give Kudo and Accept as a Solution if solution provided seems helpful.
Have a look at our Versal Design Process Hub, Versal Blogs and the Versal Forum Useful Resources
joancab
Advisor
Advisor
