Visitor reisis
Daughter cards for ML 605
I have a Xilinx ML605 - Virtex 6 FPGA  board.
In my application I need to transfer data through SMA to FPGA and from the FPGA through Gbit Ethernet ports to a network switch.
I would like to know if there are any daughter boards  available (compatible with the ML 605), that could provide me the extra SMA connectors that I need, as well as the additional SFP (and/or ethernet) ports.
If yes, do I need to obtain some extra IP cores in order to operate them?
Thank you in advance for your help.
Re: Daughter cards for ML 605
Please go through below link and section "Serial Connectivity"
http://www.xilinx.com/products/boards_kits/fmc.htm
Hope you will find FMC cards which has SMA and SFP interfaces.
