j0n
Difficulties with AC701 MIG 7 (setting 400 MHz clock clock period)
Hi all, I have an AC701 evaluation board from Xilinx and running a basic MIG7 configuration. Relevant MIG7 configuration settings are as follow:
clock period = 400 MHz
memory part= MT41J128M8XX-125 (from the drop down menu)
data width = 16
Number of bank machines = 4
Input clock period = 200 MHz
System clock: no buffer
Reference clock: Use system clock
The issue is that when using clock period of 400 MHz calib done is never high. When I reduce the clock period to 326.26 MHz in MIG configuration, then calib done is high. No other changes are made other than the input clock period which is still around 200 MHz so system clock is still used the same way.
I am pretty sure that AC701 should support 400 MHz clock period so would appreciate any help with this.
katsuki
Is this result when operating on AC701?
The memory installed in the AC701 is SO-DIMM, and the model name is MT8JTF12864HZ-1G6G1. Please refer to XTP225.
The MT41J128M8XX-125 that you specify is a component memory, so it will not work.
AR#63234 is a performance estimation guide by simulation and uses MT41J128M8XX-125.
Thank you.
Don’t forget to reply, kudo, and accept as solution. If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
katsuki
Thank you.
j0n
Hi @katsuki,
Thanks I don't know how I missed the SO-DIMM specification. I changed the configuration specifying the correct SO-DIMM now the calib done signal is high as expected. Thanks!
