Anonymous
Not applicable
Driver for K7 Connectivity TRD
Hello - I would like to know if anyone has successfully recompiled the KC705 driver that comes with the K7 Connectivity TRD to run on RHEL6?  This would allow me to use the development platform without having to reboot it every time with a Fedora 16 Live disk.
Re: Driver for K7 Connectivity TRD
The information in the following forum post http://forums.xilinx.com/xlnx/board/crawl_message?board.id=PCIe&message.id=4243 address your query
Anonymous
Not applicable
Hi - the link you provided is about getting the TRD to run under 64-bit Linux.   I'm not having a problem running it under 64-bit Linux.  In fact, I have insttalled the 64-bit version of Fedora 16 on a seperate server and it works fine with the TRD.   Ideally, what I would like is to do is compile the driver under Red Hat 6 (Or RHEL6 as noted in my original post), which is a Xilinx supported operating system.  By having the driver compile under this OS and associated kernel, I can use one OS everywhere, as well as run the TRD on the same platform as my development system.
I have provided the error log (make.log) when I try to compile under RHEL 6.5 kernel 2.6.32-431.11.2.el6.x86_64.
Thanks!
