likeyou614
EDK IIC write
In TestApp _ Peripheral =>souce
 If I hope IIC to write one data device outside
Is that written like this mistakenly? Why seem not to write? '
Suppose I set up as follows
device address =0x4C;
register address =0x03;
data =0x64;
Could you tell me where is the mistake?  thank ............
int main (void) {
Xuint8 xdata[2];
 xdata[0]=0x03;
 xdata[1]=0x64;
vsk_iic_write(XPAR_IIC_0_BASEADDR, 0X4C, xdata[0],&xdata[1],1);
Xuint8  vsk_iic_write(Xuint32 CoreAddress, Xuint8 ChipAddress, Xuint8 RegAddress,
                  Xuint8 *BufferPtr, Xuint8 ByteCount)
  Xuint8 SentByteCount;
  Xuint8 WriteBuffer[10];
  Xuint8 Index;
   * A temporary write buffer must be used which contains both the address
   * and the data to be written, put the address in first
  WriteBuffer[0] = RegAddress;
   * Put the data in the write buffer following the address.
  for (Index = 0; Index < ByteCount; Index++)
    WriteBuffer[Index + 1] = BufferPtr[Index];
   * Write data at the specified address.
  SentByteCount = XIic_DynSend(CoreAddress, ChipAddress, WriteBuffer,
                               ByteCount + 1, XIIC_STOP);
  if (SentByteCount < 1) { SentByteCount = 1; }
  // Return the number of bytes written.
  return SentByteCount - 1;
Have you tried simplifying the code by calling XIic_DynSend() from main() and verifying that it works?
int main(void)
Xuint8 xdata[2];
xdata[0]=0x03;
xdata[1]=0x64;
XIic_DynSend(XPAR_IIC_0_BASEADDR, 0x4C, xdata, sizeof(xdata), XIIC_STOP);
return 0;
likeyou614
Hi,tedevnull...
I have tried your method, but has not succeeded
Do you have relevant examples? Could post or send for my reference!
E _ mail: yzliao@j92a21.ee.ncku.edu.tw
likeyou614
I do not know well, what differences do these two functions?
XIic _ Send(u32 BaseAddress, u8 Address, u8 *BufferPtr, unsigned ByteCount, u8 Option)
XIic _ DynSend(u32 BaseAddress, u8 Address, u8 *BufferPtr, unsigned ByteCount, u8 Option)
Can you explain with me?
Thanks!
Anonymous
Not applicable
So what indeed is the difference between them?
Waiting for your reply,
Haz88
heedaf
Dyn_send doesn't use interrupts.
