Enable Graphical user interface in zcu102 board problem??
Hai Team,
I have petalinux 2018.3 version and iam using zcu102 board.I want to enable GUI in zcu102 board with my hdf file.could u please tell me what are the necessary  packages need to enable in petalinux-config -c rootfs command.???
Hi @manibenwa
Would you refer the following URL ?
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841928/Xilinx+MALI+driver
Best regards,
Thanks for replay
No .I will follow the above link and let u know the result...
I enabled the v4 utilis,multemidia,x11,QT,gstreamer in petalinux-config -c rootfs option and GUI opened successfully.
