FMC 150 ref. design
Hello
I'm currently studying the fmc150 ref. design from 4dsp to Zedboard. I already have made some progress, but now i would like to change a little bit the ref. design but i don't know how should i proceed.
For what i have studied what the ref. design is doing, is sending the data from the ADC of FMC to the host PC  using the zedboard as a server. I have to conect the zedboard to the PC using an ethernet cable and i receive the data from it. The "host" as to first run an c++ application that send commands to the FMC via ethernet to zedboard and then it receives the data via ethernet.
What i want to do is to pass this behaviour of the APP to the processor of zedboard. Is it possible? How should i proceed?
I know that this questions are dificult to answer but i'm currently struggling with this.
Thanks in advance
P.S. I attached the ISE project of the ref. design
Re: FMC 150 ref. design
The below forum posts are having related discussion
http://forums.xilinx.com/xlnx/board/crawl_message?board.id=XLNXBRD&message.id=7706
http://forums.xilinx.com/xlnx/board/crawl_message?board.id=zaps&message.id=5490
