FMC Board for PCI (not PCIe) Interface
Has anybody run across a board that converts the FMC to PCI (connector so that PCI boards can be plugged into the FPGA)
Re: FMC Board for PCI (not PCIe) Interface
I have not seen one but I doubt one would exist.  Due to the positioning requirements of FMC relative to the plane and edge of the board I would expect that any FMC to PCI "adapter" would cause the board to violate the PCI mechanical specification.
this space intentionally left blank
Since this "daughterboard" would actually function as the "mainboard" where I plug PCI cards into it, I don't see where any space constraints would be an issue, but I suspect that this particular application was not envisioned by board designers.
