FMC Pmod
I cannot seem to find the answer in the data sheet.
Are any of the Pmod ports connected to the FMC connector on the Nexys Video board? I want to connect the SPI signals to my own design, but don't have enough FMC pins.
Is it possible to test the output signal of the FMC from other than the FMC connector?
Michelle
u4223374
Advisor
Advisor
s154007@student.dtu.dk You need the schematics, not the datasheet. None of the pins appear to be shared.
