Scholar ronnywebers
FMC XM105 Debug Card : what are the typical use cases of the 'MICTOR' connector
I just received my FMC XM105 board from Xilinx, which I bought to debug my board.
I'm wondering what the 'MICTOR' connector is typically used for / why it is present on this board?
回复: FMC XM105 Debug Card : what are the typical use cases of the 'MICTOR' connector
hi @ronnywebers
below is a use case.
https://www.xilinx.com/support/answers/51878.html
Boris
Hi @ronnywebers
Generally, the mictor connector is used to connect to a logic analyzer for digital signal analysis.
hi @ronnywebers
Boris
