Visitor wenho_nxp
Failed ZCU104 Board Interface Test
Attached please find file "Failed ZCU104 Board Interface Test.pdf"
Those were screen capture from last Friday.
Today it behave differently. Once it complained COM port.
Now even failed the first test. I’m very confused. Could someone shed the light?
Thanks, Wen
Re: Failed ZCU104 Board Interface Test
What changed between the two setups? Did anything change with the UART drivers?
Visitor wenho_nxp
Last Friday I was running from:
C:\doc\Xilinx\zcu104_bit
Monday I switched to :
C:\zcu104_bit
Visitor wenho_nxp
Attached please find file "Failed ZCU104 Board Interface Test.docx"
2018/710, ran from same directory as last Friday (c:doc\Xilinx\zcu104_bit), even the first test failed.
Thanks, Wen
Visitor wenho_nxp
Still not solved.
Hi @wenho_nxp
Go through xtp504-zcu104-setup-c-2017-4.pdf. Install FTDI USB UART Drivers
Connect your board (Power ON) to PC.
Run zcu104_list_ports.bat
Bhushan
Bhushan
Visitor wenho_nxp
Attached please find "2018_7_11 Failed ZCU104 Board Interface Test.docx"
It didn't help.
Newbie kg2
I am attempting to perform the interface test as in XTP498, however I am getting similar results as 'wenho_nxp'. The topic is marked as solved but I do not see a solution to the problem. Can someone explain what needs to be done to get the interface test working?
I proceeded as follows:
  1. I followed XTP504 and installed the required drivers (CDM21228_Setup.exe) as in slide 9/16. [Refer to Image 1].
  2. I proceeded as instruct to run 'zcu104_list_ports.bat' as in slide 10/16. [Refer to Image 2].
  3. I then followed XTP498 and ran 'set_ports.bat' as in slide 6/40 with result shown in Image 3. [Refer to Image 3].
  4. Finally I ran BIT.exe as in slide 8/40 however only the first two tests passed. [Refer to Image 4].
Visitor wenho_nxp
Hi Andrew,
Thank you for your information, set_ports.bat is working now.
However, ZCU104 Board Interface still failed.
Attach please find "2018_07_31 Failed ZCU104 Board Interface Test.docx"
Thanks, Wen
Observer speedup
did you figure it out? I am struggeling with the same problem ...
