Observer tamqvu
Fatal Error. License Check failed for secure IP for feature 'ipsb_6F82'
I have a design that uses both Third-party and Xilinx's IP cores.  I am able to compile this design in Windows 10, but when I compiled in Ubuntu I got the following errors.  The attachements are outputs for report_environment and report_ip_status.
Fatal Error. License Check failed for secure IP for feature 'ipsb_6F82'. Exiting Synthesis.
License Check diagnostics :
The license feature Internal_bitstream could not be found., No such feature exists.
Feature: Internal_bitstream
License path: /home/tvu/.Xilinx/XilinxEval.lic:/home/tvu/.Xilinx/trial.lic:/tools/Xilinx/Vivado/2019.1/data/ip/core_licenses/Xilinx.lic:
FlexNet Licensing error:-5,357
Finished RTL Elaboration : Time (s): cpu = 00:00:03 ; elapsed = 00:00:04 . Memory (MB): peak = 1920.895 ; gain = 210.371 ; free physical = 11261 ; free virtual = 15182
RTL Elaboration failed
INFO: [Common 17-83] Releasing license: Synthesis
3 Infos, 2 Warnings, 0 Critical Warnings and 1 Errors encountered.
synth_design failed
ERROR: [Common 17-69] Command failed: Synthesis failed - please see the console or run log file for details
INFO: [Common 17-206] Exiting Vivado at Tue Jul 23 15:40:44 2019...
