Observer arpit.rathi
GTX Transciever loopback using example design on KCU105 with FINISAR SFP module
I am trying to use the example design of Ultrascale Transceiver wizard to perform a loopback (line rate = 1.25Gb/s) through a single SFP module (TX and RX pairs are shorted on the RJ-45 connector). The design runs fine on simulation but gives unexpected RX data in hardware.
I have double checked the GTX transceiver pins, sys_clock source and GTREF_clock source and other clock constraints. There are no timing violations. I am not sure of the issue here. Could anyone provide any insights on this?
Arpit
Re: GTX Transciever loopback using example design on KCU105 with FINISAR SFP module
As a first step you try to test the transceiver using IBERT core.
https://www.xilinx.com/products/intellectual-property/ibert_ultrascale_gth.html#documentation
If you couldn't find any issue in it we can confirm that there is no hardware related problems. Then we can go for next troubleshooting steps.
Reshma
Hi @arpit.rathi
Do you have an update to this?
Rohit
