slikke
Gerbers XtremeDSP Development Platform, Spartan-3A DSP 3400A Edition
Where can I find the Gerbers for the XtremeDSP Development Platform, Spartan-3A DSP 3400A Edition?
Thanks for your answer.
Best regards
Marco
mcgett
Gerbers are not provided for this board.  Why would you need them?
slikke
I need the distance (in mills) between the two FMC connectors to develop my own PCB.
Without the gerbers, It is not possible to measure the distance between these two connectors exactly.
That's the reason why I need the gerbers!
Best regards,
Marco
mcgett
The distance would be set to the exact value that is specified in the VITA 57.1 FMC Specification.
https://www.vita.com/online-store.html
You could also examine the distances using the ML605 Allegro BRD files that are provided as this board also has double wide FMC capability.
eteam00
Instructor
Instructor
I'm just guessing --
  • It may be that the exact distance is not as important as the knowledge that the distances from the FMC connector to the FPGA pins are (more or less) exactly matched.  In other words, the layout skew is more important than the absolute length.
  • If the VITA spec includes proscribed trace length from FMC connector to FPGA pin, then it stands to reason that ANY VITA-compliant board should match all other VITA-compliant boards in this respect.  If this is the case, then the Gerbers for any VITA-compliant board would give you the information you seek.
-- Bob Elkind
SIGNATURE:
Summary:
mcgett
I don't think that the OP was interested in the trace lengths (and this is not specified in the VITA spec), but in the physical layout distances between the two FMC connectors so that they could create a double-wide FMC module to plug into the board.  These distances are part of the FMC specification to ensure mechanical compatibility between Carrier Cards and FMCs.
eteam00
Instructor
Instructor
Thank you for snapping me back to reality, Ed.  This makes sense, completely.
Having said that, I can cheerfully boast that -- although my rationale was completely and utterly mistaken -- my assertion is proven:  the Gerbers for any VITA-compliant double-connector board should provide the information which is sought.
I can now revel in the warm comfort of being completely right -- by accident rather than by intent (and not the first time, I might add).
-- Bob Elkind
SIGNATURE:
Summary:
slikke
Yes, I am interested in the physical layout distances between the two FMC connectors so that I can create a double-wide FMC module to plug into the board.
Thank you for your answers.
Marco
