How to change GTY ports Differential peak-to-peak output voltage in VCU108 EB?
Hi, I use VCU108 EB in my projects, and I used ports of AL40 and AL41 in GTY bank 126 to transmite my signal. I want to change ports output differential peak-to-peak output voltage, I read the relevant description in DS893, and as described in following picture
but I couldnt find how to change in ug578.I just find in following picture,and hwo to do ?
What  is the default output voltage?  Is 800mv of min?
And what is the max output voltage? Is 800mv ?
I should how to change ?
Best wish!
回复: How to change GTY ports Differential peak-to-peak output voltage in VCU108 EB?
Dose anyone have good solutions?
@zengqh Hi,
You can check "TXDIFFCTRL" in the UG578.
